It is currently Tue Jul 08, 2025 9:36 am
PostPosted: Thu Oct 25, 2007 9:53 pm
Not the best pic-
Question:
On this set-up,at the exhaust rockers on the end,is there suppose to be a coil washer?Or does this set-up run a flat washer only?
PostPosted: Thu Oct 25, 2007 10:10 pm
Pretty sure it's flat washer only. Like a Cooper S.
I'll check mine tomorrow if you like. :wink:
PostPosted: Thu Oct 25, 2007 10:25 pm
Thanks-Much appreciated.
This set-up has only flat washers-no coil washer and very noisy at number No1.(clearance checked and double checked).
PostPosted: Thu Oct 25, 2007 10:40 pm
If there's room for a coil washer fit it, otherwise make a thicker washer to take up the slack.
Are you sure it's not a worn bush....
PostPosted: Thu Oct 25, 2007 10:47 pm
Thanks-Thats next....it sounds like a hot EH 179 with hydraulic lifters :oops:
PostPosted: Sun Oct 28, 2007 10:00 am
OK I just checked mine- yes they DO have the coil spring each end, and a flat washer.
You buy these Minispares forged rockers as a kit- all you get is the rockers, a HD shaft and 4 new posts.
You make your own arrangements regarding using your old parts on assembly. I apparently had room for the coil springs. 8)
PostPosted: Sun Oct 28, 2007 8:02 pm
Thanks Kevin-I'm going to muck around with the coil spring,but I'm thinking bush as well.
