It is currently Sun Jul 06, 2025 3:14 pm
PostPosted: Sat Jan 20, 2007 7:04 pm
Anyone know the size of the inlet and exhaust vales on a standard Rover Mini?
Also, is the head any different to that of an older 1100?
S
To have a true objective opinion on all things motoring, one must experience a variety of configerations and combinations on a regular basis in an effort to not form an excessive attachment... Oh who am I kidding...
PostPosted: Sat Jan 20, 2007 7:40 pm
As far as I know the valves are the same size. I would guess they would be similar to a 202. I do know they have bigger water galleries.
PostPosted: Sat Jan 20, 2007 8:08 pm
no such thing as an 1100 in a rover mini.. just to be pedantic ;)
of course, I'm usually wrong about Rover stuff, willy will correct me
PostPosted: Sat Jan 20, 2007 8:19 pm
I'll guess you're looking to swap one out on the 1100 you own?
PostPosted: Sat Jan 20, 2007 8:26 pm
There is not much 1100 anywhere other than Australia apparently.
PostPosted: Mon Jan 22, 2007 10:58 am
Am looking at buying a 1100 Rover Mini.
I already have a ported 202 head so thought I'd build one for high compression
and the other for forced induction.
Wanted to know if the Rover had any better flow, so I can decide which head to do what with.. If that makes any sense.
S
PostPosted: Mon Jan 22, 2007 5:54 pm
Definitely no such thing as an 1100 engine from a Rover.
A 202 head (from a 1098) will go onto a 998 block.
PostPosted: Tue Jan 23, 2007 12:50 am
i have had a great deal of trouble getting any mini that doesnt have an 1100
PostPosted: Tue Jan 23, 2007 12:23 pm
I don't get it?!
Isn't a 1098 the same as an 1100 (uno just a stroked 998)
In any event I thought the 1098's had a 202 head.
So what's the go?
PostPosted: Tue Jan 23, 2007 1:59 pm
ok, firstly, lots of UK clubmans were 1100's (1098) which aussies will call "rovers", but clubman production in the uk ended in 79? (81 for the 1275gt)
secondly, lateish (80's) rover 998's will have the camxxxx head, which has small valves, unleaded seats, low compression and solid rockers.....throw it away and put the 202 on :D
PostPosted: Wed Jan 24, 2007 4:39 pm
The car I was looking at is a 1987 Rover built Mini, with round nose front.
Definately unleaded. Has 1100 stamped on the block.
Doesn't it already have a 202 head?
PostPosted: Wed Jan 24, 2007 5:25 pm
that late, if its a standard car, the engine will not be an 1100, where on the engine does it say 1100? only fairly early (60s?) 1098's had 1100 stamped on a plate riveted to the back of the engine.
whats the engine number?
:P
