It is currently Sat Jul 05, 2025 4:14 pm
Post new topic Reply to topic  [ 107 posts ]  Go to page 1, 2, 3, 4, 5 ... 8  Next
PostPosted: Fri Jan 05, 2007 12:31 pm
What makes a mini engine die?
Oil starvation, and wear and tear are obvious, but what causes are there and what can be done to prevent it?
Discuss. :)
PostPosted: Fri Jan 05, 2007 12:35 pm
Cooling , cooling and cooling , make sure the cooling system is as good if not better than when they roled out of the factory . Nothing worse than having a hyper motor that you can't use fully because it overheats when pushed . Also because it can kill it quickly ....
PostPosted: Fri Jan 05, 2007 12:37 pm
So how do you improve it?
(semi-rhetorical) ;)
PostPosted: Fri Jan 05, 2007 12:38 pm
Acid clean the block to make sure there's nothing hiding in the waterways , new radiator or better radiator , timing right , umm ....
PostPosted: Fri Jan 05, 2007 12:45 pm
Slow-Po
Thermo fan.
PostPosted: Fri Jan 05, 2007 12:49 pm
willy, put him in a Verada
PostPosted: Fri Jan 05, 2007 12:53 pm
speedy wrote:
Thermo fan.
how can that cool better than a crank driven fan?
that'd free up some power, but would it cool better?
PostPosted: Fri Jan 05, 2007 1:02 pm
cush wrote:
speedy wrote:
Thermo fan.
the speed of the fan is not tied to the speed of the engine. So you can have a 5000rpm fan acting on radiator of a 750 rpm engine.
PostPosted: Fri Jan 05, 2007 1:39 pm
Slow-Po
Its efficiency is not dependant upon on engine or vehicle speed. Your question was regarding making a bullet proof A-series, and this mod would IMHO be necessary for a street engine.
 Post subject: Oil
PostPosted: Fri Jan 05, 2007 1:50 pm
Oil is the best mechanic (my Dad told me that) :D
so..don't be afraid to change your oil on a regular basis.
PostPosted: Fri Jan 05, 2007 2:05 pm
ah.. i didn't think of that..
thermo fans would attach to the same temp sender point and be located in the same place...
who does them?
feel free people to open this discussion up and make this an utterly thorough guide... :)
PostPosted: Fri Jan 05, 2007 2:28 pm
Standard 998s with 1.25" SU and pea shooter are fairly bullet proof coz you can't rev them past 4000rpm :)
The thermo fan runs off a seperate sender which can either be put into the top rad hose or put a thermo cover with a sender hole in the side. Another benefit is you can leave the fan running with the engine off, which is also a benefit of an electric water pump, but I've never seen someone running one on an A series donk.
PostPosted: Fri Jan 05, 2007 2:29 pm
is an electric oil pump a bad idea ?
PostPosted: Fri Jan 05, 2007 2:54 pm
Get a fully rebuilt 'S' motor, certain main strap, better oil pump, better crank, basically better everything, and don't put big exhasut and webers and stuff on to keep the ability to rev low.
Failing that, just thrash out a 998 till it blows up, then buy another, and do the same with that, then when loacl supply runs out import from Japan (thanks Steve!) and continue.
:D
PostPosted: Fri Jan 05, 2007 2:56 pm
A guy in SA runs one on his Sports Sedan and another Sports Sedan I've seen in THE.
http://www.hotbricks.org.au/members/rides/simon/index.htm
