It is currently Sun Jul 06, 2025 10:24 am
 Post subject: morris 1100
PostPosted: Fri Dec 23, 2005 10:33 pm
hi guys, new here. i have just picked up a morris 1100, running the 1098 motor. i am getting a "stage 1" tuning kit for it, hi flow water pump, 4 core radiator and an oil cooler. she runs real hot, hopefully this will fix it.
what i wanna know is. what is the next move from here? bear in mind that it will be a daily driver, while i go stupid on the real deal (a mini yet to be bought)
match porting???
cam???
don't wanna spend too much more, wanna save for the mini, thanks guys
PostPosted: Sat Dec 24, 2005 7:02 am
You can pick up an easy 3HP or so if you fit an HS4 carb & manifold off a 998 Clubby.
That HS2 is just too small for a deep breathin' 1098... :wink:
PostPosted: Sat Dec 24, 2005 8:05 am
hmm sounds like a plan Kev,
i may do that to pick up some more HP for the next dyno.
Jet Red Mini K
PostPosted: Sun Dec 25, 2005 12:45 am
thanks. would it be hard to locate one of these carbs? mine is 1.5" now, and i'm getting the water heated manifold from minisports.
PostPosted: Thu Jan 05, 2006 2:35 pm
also seems like alot of you guys are in the hills district. why have i never seen your mini's around?
PostPosted: Thu Jan 05, 2006 6:16 pm
Nathan, your 1-1/2" carb already IS an HS4.
These were stock carb on 998 Clubbies, also on all the Oz MiniMatics and Morris 1100S(1300) autos.
850, Mini Deluxe, Mini K and 1098 Clubby only got an HS2 (1-1/4"). Swapping that for an HS4 is worth around 3HP or so on an 850, according to Clive Trickey. (remember him?) :lol:
Probably more on the bigger motors.
 Post subject: hiding...
PostPosted: Thu Jan 05, 2006 7:18 pm
Nathan....they are there....just that they are all either working on their cars, drinking JDs or inside on Ausmini :D
