wanna_bea_driva wrote:
The front apron (as in behind the front bumper) has had a hit in the past. it as a new bumper and grille, so they are both fine, but the pnnel underneath is rusted out. It really needs to be replaced, can i buy a new pannel, if so where from, otherwise will i need to buy and old front end and cut myself a fresh piece???
I have seen a few replacement panels come up on ebay but $$$ I'm afraid maybe find a price on the replacement panel and see what a panel beater says....
I am planing to put a larger carb and a set of LCBs on once its registered, should i just do it beforehand though???
No use rebuilding a carby your going to get rid of anyway
it is a standard 998, matching numbers even, what size will the carb on it now be, and what size would you recomend.
I'm guesing but 1 1/4 for a 998
maybe you could go to an 1 1/2. 1 3/4s tend to be used on 1100s and 998s so possibly a bit big, but see what everyone else says......
