It is currently Tue Jul 01, 2025 11:33 pm
 Post subject: help with painting
PostPosted: Mon Nov 21, 2005 5:29 pm
im currently in the process of stripping down my car (a '74 clubman :twisted: ) and wanto know what was the best way u found to be the easiest way to remove the paint from the car and the methods you used .
and other tips todo with paint would help
cheer tait.
PostPosted: Mon Nov 21, 2005 6:11 pm
Location: thornleigh sydney...round crnr from suzitech!!!!
to do my engine bay in the van i too it back to bare metal using an electric drill and a coarse wiere brush attachment, took off old tar and paint with ease!
im still yet to do the exterior though...ill be paying attention to this thread aswell!
blake :wink:
ausmini member 195
71K 'Kaye', KAZZ69's work in progress
66 panelvan, going no where fast...
71 MS75 toyota crown COUPE :) yes A COUPE!
76 ra23 celica wid 1ggte, GT3071r, 13.5@106mph with alot of spinin....
wheels keep on turnin!
PostPosted: Mon Nov 21, 2005 6:34 pm
i use paint stripper on all large areas and a small sand blaster for the areas it cant get.
1974 Moke - 998cc
PostPosted: Mon Nov 21, 2005 7:11 pm
im gonna try a random orbital for my first go i aint taking any risks :lol: :lol:
My rides-74 fj40
74 clubman hopefully rego'd soon....
and 76 clubbie van!! - Ratschite after what i found what it was covered in when i found her...
http://photobucket.com/albums/b44/minimechanic/?sc=1
PostPosted: Mon Nov 21, 2005 8:18 pm
I tried stripper, and it took five coats to remove shag-all. Plus the stripper went behind strengthening bars & ribs (I was practicing on a bootlid), when I couldn't see what was happening or get all of it our, or recoat effectively.
Sanding it off takes a LONG time and scratches the surface, probably makes the metal a bit thinner too.
Paint stripping wheels (like 3M fibre disks) on an angle grinder are, I think, the best. You don't remove steel, you don't have toxic mess to clean up or wash down the drain, and it's cheaper. It depends on how much noise your neighbours can put up with. One thing: Use them carefully as if they catch an edge, they get ripped up pretty quick. Wire cup wheels are also good, and more robust although when new they can scratch up the metal a little.
Another caveat: I rooted my DeWalt angle grinder by using it too long - POS. So I bought a cheap B&D which works just as well, but cost 1/4.
PostPosted: Fri Nov 25, 2005 4:56 pm
well here's a fun tip for all those budding nutcases, i was paintballing today and we were joking around saying we should play inbetween the cars, untill the owner told us if you left the paint on the car to dry it works like paint stripper! so you could have a bit of fun shooting your car with different colours, pretending your on acid for a day while driving it around then wash it off with the original paint coming off aswell.
( WARNING: I do not endorse the use of weapons against mini's, nor the validity of proffesional paintball players stories. guns are bad)
With great power comes great responsibility. It also comes with one kick ass ride.
PostPosted: Mon Nov 28, 2005 5:48 am
If there are layers and layers of paint, the ideal way is to paint strip it until you get close to bare metal or until no more paint can be striped then electronically sand the rest with a very fine sand paper. It's a bit messy but the work pays off.
Tips when using paint stripper is to lay out wall paper around what ever your paint stripping as it won't burn the paper. When you do start removing the paint put the crap that's scraped off into the wall paper and simply roll up and throw out. Do not strip the paint over the grass as it will kill the grass and could start a fire.
DO IT ONCE, DO IT RIGHT
