It is currently Fri Jun 27, 2025 2:27 am
Post new topic Reply to topic  [ 305 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 21  Next
PostPosted: Wed Nov 21, 2007 7:40 pm
Pete come by, I have a sheet of real SS you can hack up. 8)
PostPosted: Thu Nov 22, 2007 12:57 am
in regards to the pictures "Grant took at MDU last year"
can i ask what people use on the firwall is that a small piece
of stainless steal or is it a mirror? i wanna do that to mine
when it comes time for engine bay paint
Mearcat wrote:
PostPosted: Thu Nov 22, 2007 6:16 am
have you seen this thread dbr11k
http://www.ausmini.com/forums/viewtopic ... highlight=
PostPosted: Thu Nov 22, 2007 9:15 am
That is a sheet of 304 stainless, about 1.2mm thick from memory. I cut/drilled it using an 850 speedo housing as a template. It is mounted using the original screws. It is not polished, thats how it looks 'as rolled' and is good for keeping the heat from melting wires etc. I don't have a speedo anymore but I never used it anyway, the car only has two speeds, stop and oh s#$t! :lol:
Daniel
PostPosted: Thu Nov 22, 2007 1:34 pm
ausmini mod
ausmini mod
Sweet! Thanks Kev... deal :)
PostPosted: Fri Nov 23, 2007 11:50 am
hay guys
just been filling through aus mini and found ur post.
i've been building a 1275 metro turbo.
ive made mine the same as standard(with turbo behind engine) and am almost ready to drive
just thought id drop a line to say hello, and complement you on ur work.
PostPosted: Fri Nov 23, 2007 12:09 pm
We need more turbo A-Series on here, tell your friends!
Daniel
PostPosted: Fri Nov 23, 2007 7:33 pm
With such large power output figures, 150hp, are you planning to do anything with the drive line components? Or, will standard components suffice?
I would have thought at least a crosspin diff but what else?
PostPosted: Fri Nov 23, 2007 7:49 pm
i'd look at a stronger box with aftermarket parts (straight cut or sommit) or an A+ gearbox which is stronger
3 of us in adelaide that i know of have blown gearboxes with superchargers.
PostPosted: Sat Nov 24, 2007 7:41 am
ausmini mod
ausmini mod
Its a rebuilt box, but stock (well, I lie, competition pin, etc) but basically stock
Gearboxes dont break because of the power... they generally break due to a faulty part or the way you drive.
Give me a stock standard 998 (bugger all HP) with a newly rebuilt box and I could break it... depends how you treat it.
I would love to go LSD, stronger box, etc... but for now, this is fine... and has been shown to work fine even with very strong motors.
Pete.
PostPosted: Sat Nov 24, 2007 9:51 am
I agree, if you drive a Mini like some people drive ricers you will break it, regardless- but used sensibly a stock box will handle 180HP.
Boostedmini ran a stocko Mini-K box in his turbo 1360? stroker for 5 years or so. :D
PostPosted: Sun Nov 25, 2007 4:28 pm
Pete.
i have a rebuilt box, all new bearings, comp layshaft, rebuilt diff, comp diff pin
still couldnt cope, the gears themselves arent strong enough.
PostPosted: Sun Nov 25, 2007 6:16 pm
So how did you make it strong enough :)
PostPosted: Sun Nov 25, 2007 6:42 pm
over here we had tested the "competition diff pin", it's not superior to the normal factory part. latest finding is that the "steel competition baulk rings" are wearing much faster than standard Rover parts
please tell more, best with pics, as i have never seen the gears themself fail due to torque alone. the last gearset failing i know of was a straight cut with some "special hardening". the surface was much to hard and broke away like glass
Rover 214 atm ....
PostPosted: Sun Nov 25, 2007 7:43 pm
Bit of an armature question with the gears but can they be hardened or is this already done standard or what?
