It is currently Thu Jun 26, 2025 8:28 pm
Post new topic Reply to topic  [ 47 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Fri Apr 01, 2005 5:18 pm
fuzzy-hair-man wrote:
You should be able to pull the rod out of the middle by taking out a rubber seal at the end of the remote change and then it should be easy to get the nylon gearstick bush out. Or I just stuck my little finger inside it from the top and pulled it out but maybe my little finger is the right size :P
Are you sure that's all it takes? I tried pulling it out with pliers, trying to hook onto it with a bent piece of metal but bo good! she's int here tight and it's very small too!
PostPosted: Fri Apr 01, 2005 5:24 pm
It's all mine took but as I say mine was stuffed
maybe if you take the rubber cover bit off and undo that nut you will be able to get the cast bit that it sits in out and then you should be in a better position to attack it
I think the rubber cover/ seal thing was on the side now, I can't remember :oops:
My new one was tight on the gearstick but loose in the remote change I pulled the new one in and out several times I think just fiddling :D
Roads need more corners
Users browsing this forum: No registered users and 24 guests
