It is currently Thu Jul 03, 2025 12:57 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3
PostPosted: Thu Mar 16, 2006 6:53 pm
Vizard reckons a stock Mini flywheel/clutch/backplate assembly is around 28lbs (12.72kg) and the 1300 type is 32 lbs (14.55kg).
So that makes the 1300 flywheel 4lbs (1.83kg) heavier.
I just weighed Cody's old Morris 1100S1300 flywheel (with the big rim weights) it went 8.1kg on my scales. So I reckon the stock Mini one weighs 6.27kg.
I'll dig one out and weigh it tomorrow. :wink:
PostPosted: Fri Mar 17, 2006 5:42 am
suppose it depends on what kind of flywheel you use as a base line either way they are f king heavy.
let us know what you find with the wieghts.
www.minicranks.com add me to your watch list and come back again soon, under construction.
PostPosted: Fri Mar 17, 2006 5:50 am
I think there's definitely a few different 'standard' flywheels. I know in the small bores I've ripped apart I found wheels that were quite obviously not lightened, but I could tell they were different just by feel. I'm guessing that would have to be close to a kg for me to be able to tell. My scales only go to 5kg so not 100% sure.
PostPosted: Fri Mar 17, 2006 5:54 am
when you find a flywheel your scales can measure keep it.
from memory there are about 4 different types of flywheels from the std mini production and they vary in a big way.
so stu i was right about the weight hey hey, huh, you thought i was miles out hey. haha
PostPosted: Fri Mar 17, 2006 5:59 am
Yep :shock: There just seemd to be a big jump up to the 12.whatever but a little bit here and a little bit there all adds up.
Like I said the other day I've got that 4.something lightened one sitting here but Lyn Rogers reckons maybe not on a big bore (and he made it so I'm listening!).
PostPosted: Sat Mar 18, 2006 7:22 am
does anybody know is u can use a auto torque convertor bolt on manual fly wheel it is slightly thicker
PostPosted: Sat Mar 18, 2006 7:26 am
Thread is the same, if head is too thick though it can foul inside the diaphragm's thrust ring for the throwout bearing.
PostPosted: Sat Mar 18, 2006 1:32 pm
thanks kev i went a got a propper one in the end
