It is currently Sat Jun 28, 2025 1:48 am
PostPosted: Mon May 16, 2005 1:09 pm
hey all,
ive just finished reading this post and im sure id find it even more informative if i knew what the hell pinging was!! so could you please help a not so mechanically minded person out and explain what it is!! thanks
trent :?
PostPosted: Mon May 16, 2005 1:23 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
when you give the motor a gut full and you hear a nocking or pinging sound
makka
PostPosted: Mon May 16, 2005 2:12 pm
makka
It's a "tinkle tinkle" sound heard mostly at low revs (under 2500) when you give it full throttle.
PostPosted: Mon May 16, 2005 5:44 pm
best way is get her goinmg at around 30 Mile and put your foot to the floor in 4th...You may hear it
PostPosted: Mon May 16, 2005 8:22 pm
I thought my Yamaha R1 would be the peak of hi tech engine management stuff, but even it can't get away from the crap fuel we sometimes get fed.
When it pings (usually only when very hot and with less than perfect fuel) it's like someone is bashing my engine with ball pien hammers. Can't miss it (or the semi in the rear view mirror).
PostPosted: Mon May 16, 2005 8:50 pm
Just talking to Fred Sayers and he and Graham Russel are both in agreement that max advance should be 28 to 30. Any ideas on this?
PostPosted: Mon May 16, 2005 9:42 pm
Probably about right, for a near stock motor.
My last 1310 (bathtubbed chambers, flat top pistons, 10.4:1 C/R & RE-13 cam) ran at 41*.
I didn't believe it either- double checked it- but every time I knocked it back a degree or two, it lost power.
Graham R says yeah, open chambers DO need more advance, but the higher the C/R the less they need.
Greig Malaure's Nb race car runs about 37*.
My current 1360 is running at 40*. Same head... 8)
 Post subject: Greig
PostPosted: Mon May 16, 2005 10:28 pm
Proud of you Doc....Greig Malaure's Nb race car runs about 37*. :wink: :wink:
I find it truly amazing that people are achieving such high power outputs from the venerable old A Series AND reliably :!: ....sweet 8)
 Post subject: Re: Greig
PostPosted: Mon May 16, 2005 10:32 pm
And without need of `hair dryers'.. :lol:
