meehal wrote:
so a carby and manifold like this would suit ok? After a rebuild and a clean....
http://cgi.ebay.com.au/Mini-Rover-1988- ... dZViewItemcheers.
it'd be fine, but as I referred to before, if you want to run extractors with that manifold, it'd need to be cut... if you weren't concerned about extractors, then you're on a winner, might even connect up to your existing exhaust system, though would be a little asthmatic. According to Mr Vizard, you'd be looking at a H6 or an M needle without extractors.
Adding extractors to an engine will give more performance gain than adding carb - consider this, if you can't get the gases out, what's the point of trying to shove more in...
did I tell you that I won a
trophy?
