It is currently Tue Jul 08, 2025 1:53 pm
PostPosted: Sat Aug 04, 2007 2:13 pm
OK I've finished them and bolted on- with .016" clearance, valve lift is now 0.365". :D
Bush bore offset is 1.1mm.
Not bad for a crappy old set of 850/998 pressed steel rockers- so old that the pillars were alloy. Can't remember when they dropped those and went to cast iron... :?
The alloy ones often used to collapse under head stud tension = another blown head gasket for you......... :evil:
<edit> syntax
<edit 2> rocker ratio is now 1.31:1
Last edited by drmini in aust on Tue Aug 07, 2007 9:28 am, edited 2 times in total.
PostPosted: Sat Aug 04, 2007 11:01 pm
Thats sounds almost perfect Kev 8)
except for the pillars
PostPosted: Sun Aug 05, 2007 7:35 am
Of course I'm NOT using the old corroded alloy pillars Gaf, I have cast iron (so-called `steel') ones off an S set. :lol:
