It is currently Thu Jul 03, 2025 2:02 am
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Tue Mar 07, 2006 6:58 am
That's all good for those that drive LHD minis, only your passenger will lost his nuts! :shock:
PostPosted: Tue Mar 07, 2006 9:54 pm
Nah, that`s a one piece flywheel with integral ring gear, great for accelleration, but will need an idle speed of about 1500rpms & upwards to keep the girl running
PostPosted: Wed Mar 08, 2006 7:00 am
yeah. i was pissed :( i wanted my BLING fitted..
But must admit the Drmini special looks VERY good.. :wink:
PostPosted: Wed Mar 08, 2006 8:26 pm
Any chance you guys can quote some weights for these different flywheels :?
Matt, what does yours weigh after the CNC machine is finnished with it??
Whats a standard one weigh for comparison :wink:
Minimad
You can take the boy out of the racer.........but not the racer out of the boy!
PostPosted: Thu Mar 09, 2006 9:48 am
It's not so much the total weight, it's where the mass is removed from.
In order to reduce rotational inertia, material should be removed from the outer section of the flywheel.
The amount of energy required to spin up/slow down a rotating object is based upon mass x radius^2, so where is more important than how much :wink:
PostPosted: Thu Mar 09, 2006 6:31 pm
After I lightened a stock Mini flywheel for Cody he gave me his old one, off a Morris 1100S. (commonly known as a 1300 flywheel).:roll:
Holy crap Batman, are those things heavy or what! :shock:
They have this bloody big cast ring around the outside. Tractor flywheel, I'd call it. :lol:
PostPosted: Thu Mar 09, 2006 6:36 pm
Just a little more meat for jenny craig :lol:
PostPosted: Thu Mar 09, 2006 9:23 pm
Keeping in mind AWDMOKE's bit of advice with regards to where the metal is scavenged from, I measured Matt's flywheel at a shade over 5.2 Kgs
Mick
PostPosted: Fri Mar 10, 2006 12:17 am
5.2 kg . thanks
Time to weigh a standard one
Minimad
PostPosted: Fri Mar 10, 2006 12:44 am
Standard? :? BMC didn't have standards!
You mean a steel flywheel? Or a cast iron flywheel? Or a Morrie 1100 flywheel? Or ...
PostPosted: Fri Mar 10, 2006 7:12 am
Doc, don't you machine 0.2" off the face of the standard flywheels to lighten them?
Mini - The Wizardry on Wheels!
PostPosted: Fri Mar 10, 2006 8:54 am
Yes I do, then I take another cut from the outside down to outer edge of the 3 holes, leaving 2.5mm material against the ring gear.
Vizard says you can lighten the engine side of it too, I generally don't bother for roady flywheels. :wink:
PostPosted: Thu Mar 16, 2006 5:49 am
std flwheel weight is about 8kgs
the mini spares one is 3.8kgs
the swiftune ultra light is 3.2kgs
my own lightened one is 4.8kgs
aluminium race ones 3.4kgs
titanium one 3.6kgs
should slways try keep the road ones and any lightened ones around 5kgs or it tends to weaken to a point of self distruction and let me tell you you have a cutting disk doing 8000rpm right between your legs a flmsy little firewhall aint goin keep it out from cutting your gonads off.
std clutch set up wieghs about 12.4kgs
My race car set up wieghs 5.2kgs
my raod car set up wieghs6.5kgs
dont need any more revs to get her gogin as she will light the wheels up i just need to feather the clutch a little.
www.minicranks.com add me to your watch list and come back again soon, under construction.
PostPosted: Thu Mar 16, 2006 8:22 am
J, standard clutch 12.4??
PostPosted: Thu Mar 16, 2006 5:45 pm
std cluch set up woith flywheel, backing plate diag[ramn etc.
flywheel 7.6kgs
backing plate 2.6kgs
clutch plate 1kg
spring 1.2kgs
exact figures form minispares and im sure that there are heavier flywheels.
than other but dunno which one they are weighing.
Users browsing this forum: No registered users and 29 guests
