It is currently Mon Jun 23, 2025 5:05 am
 Post subject: Pinion 8 port head
PostPosted: Wed Apr 22, 2015 7:39 pm
http://www.ebay.com.au/itm/MINI-MORRIS- ... 27fd83d84e
This is on ebay now, I never knew about them and looking at it to me it seems like it has 12 ports :? unless one set of 4 ports are for cooling or something.
Peoples thoughts and comments.
 Post subject: Re: Pinion 8 port head
PostPosted: Wed Apr 22, 2015 8:05 pm
An interesting head...
Very odd design!
PostPosted: Wed Apr 22, 2015 9:00 pm
you're right Kenno, the piece of aluminium square section in the last photo is a water manifold that's bolted to the top rear set of ports
http://mk1-performance-conversions.co.u ... 8_port.htm
one of ~10 made, pretty rare!
PostPosted: Thu Apr 23, 2015 7:52 am
There is an 8 port thread on mk1 forum, and the below is in reference to that head on eBay...
dbo wrote:
That Pinion Port was originally run on a 970 and short stroke (58mm) 999 in Victoria BC, Canada by John Erith. It was damaged I believe in the late 70's early 80's and was sold to a friend in Victoria BC, then to another in Texas, USA and then sold to Australia. The intake Manifold and twin 40 DCOE's I believe are still in Texas. I had a few sets or valves for it (now sold) but I may still have some although not a complete set. Cool to see it show up again.
Dennis
Here is the thread
http://mk1-forum.net/viewtopic.php?f=3& ... ion#p95008
PostPosted: Sun Apr 26, 2015 1:21 pm
Surely he's joking expecting $1500 for a head with that much corrosion...
-----Better is the enemy of good-----
-1976 Yellow Devil Leyland Clubman-
-1970 Morris Mini Van - Work in progress-
PostPosted: Sun Apr 26, 2015 8:01 pm
its worth that just as a piece of history sitting on the shelf
PostPosted: Mon Apr 27, 2015 4:22 pm
Well it's much easier to fix an alloy head with corrosion than an iron head.. I'm sure if someone wanted to save it they could
PostPosted: Mon Apr 27, 2015 4:39 pm
:roll:
Have a Nice Day.
PostPosted: Mon Apr 27, 2015 4:50 pm
Obviously repair wasn't economical back in the day.
Is repair possible these days, or will it always remain an exhibit?
Once upon a time iron block and head repairs were just about impossible as well...
PostPosted: Mon Apr 27, 2015 6:59 pm
Looks like head porosity to me. Also interesting that there appears to be a break between the valves, with the seats either side.
