It is currently Fri Jun 27, 2025 9:11 pm
PostPosted: Sat Feb 25, 2012 12:13 am
Hi, just wondering if anyone knows who can supply the end spline part for Mini steering columns? Apparently a guy in Queensland makes them but having trouble getting any info. They are available from Minisport but are quite expensive!
Any help / suggestions who to try greatly appreciated.........
I'll see you IN a MINI !!!!
PostPosted: Sat Feb 25, 2012 7:22 am
Mini King has some original factory forgings, but they are unmachined.
I got prices recently for machining them, but the cost was prohibitive.
I then got a price to CNC machine some from bar stock and wire cut the splines in, the minimum qty worth making was a problem, & it was expensive too.
The main problem to do them cheaply is finding someone with a 9/16 x 36 tooth SAE spline pull-thru broaching tool, or putting up the $$$$ to get one made. Nobody knows what happened to the original tooling back in 1978 or whenever.
The next problem is welding them onto the shaft- these days they would probably need to be TIG welded by a certified welder.
PostPosted: Sat Feb 25, 2012 10:57 am
This mob is in Qld http://www.gearconcern.com.au/contact.htm
David L
PostPosted: Sat Feb 25, 2012 11:00 am
Why isn't my post showing ???
David L
PostPosted: Sat Feb 25, 2012 11:04 am
http://www.gearconcern.com.au/contact.htm are in Qld
David L
PostPosted: Sun Feb 26, 2012 8:18 pm
Hi Dr Mini and Wombat!
Thanks both of you for that info, will give them a try this week!
CHEERS, AG!
PostPosted: Sun Feb 26, 2012 8:41 pm
Tony & Andrew from Minisport Australia (Adelaide) have these end pieces in stock
PostPosted: Sun Feb 26, 2012 9:28 pm
Geez and I thought my CNC quote was dear!!! :shock:
[edit] But I'm glad to see they are available for those in need.
8)
http://minisport.com.au/prod2222.htm
Last edited by drmini in aust on Mon Feb 27, 2012 11:52 am, edited 1 time in total.
PostPosted: Mon Feb 27, 2012 9:26 am
i was going to get my Guy to make them (a while ago) but there wasn`t really very much support or encouragment,,, i could have probably made them avaliable for about $60 each but like i said, there just wasn`t anyone interested & a whole heap of people kept telling me that minisport already have them,,, so i didn`t really want to step on anyones toes,,, so i didn`t bother making them,,, i`m making other stuff instead :-)
