It is currently Fri Jun 27, 2025 10:24 pm
PostPosted: Sun Apr 10, 2005 9:09 am
Makka, all the touble has been around PORT injection, I'm proposing "Wet Manifold" (or Throttle-Body injection - electronic carbie if you wish...)
By injecting further upstream, you add a larger "plenum" effect to the inlet port, BUT you loose some of the subtle niceties of MPI, like fuel now sticks to the port walls, so you loose a "little" efficiency and top-end power (1hp maybe ?)
remember the old Kinsler injection that everyone semed to use on blown V8s in the 80s ? - similar concept.....
J
PostPosted: Sun Apr 10, 2005 11:19 pm
**NEWS just to hand**
It has come to my attention that there is a very cheap computer on the market that can be reprogrammed very easily, and would be good for my setup.... I've had 3 different sources confirm this.
Can anybody say "Holden Camira"
Yep, aparrently its true. The old Camira has some electronics that may come in handy.
Time to do some research.
PostPosted: Mon Apr 11, 2005 8:23 am
Isnt that just a Delco 1227808 ?
(Same unit as used on the Camira, Pulsar, VN/VP V6 commodores... and a heap of others ?)
maybe ther eis another unit..... but yea, the delco is a fantastic computer, but a bitch to tune !
J
PostPosted: Mon Apr 11, 2005 11:19 am
I've posted this a coupla times before in other threads. My mates are building a engine management computer at the moment. Is just had the trademark registered and is allmost completed beta testing phase. Its mainly for LPG & LPG injection but can do petrol EFI as well. I'm in the middle of having mine installed. When this is out of beta testing and retaling this should be a lot cheaper solution that a wolf3d + its australian. If your in WA and you race your minis it would be good if you get in contact and be a part of the beta testing phase. Unlucky if your over east.
Ive seen the thing installed in ford laser with LPG. With a car full of adults the thing belts along.
www.profire.com.au
Clayton
1965 850 Mini Van
1972 Clubman Van
Member of SDMC
Users browsing this forum: No registered users and 26 guests
