It is currently Sat Jun 28, 2025 12:41 am
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
PostPosted: Sat Apr 09, 2005 6:26 am
68Delux wrote:
What about if your speedo works but your odometer doesn't?? obviously the cable turns then right?
There is a separate ratchet & pawl mechanism inside, also driven by the cable- that drives the odometer forward. What happens is the number tumblers stick, then the ratchet slips and doesn't drive. Sometimes you can fix this by removing the brass ratchet arm (easy) and sharpening the blade on it.
I'll give you an old speedo to play with.. :wink:
PostPosted: Sat Apr 09, 2005 10:59 am
thanks for the info, i have some idea of what to do now :)
Users browsing this forum: No registered users and 35 guests
