It is currently Thu Jul 03, 2025 7:42 am
Post new topic Reply to topic  [ 56 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Tue Nov 01, 2005 11:41 am
its a cams approved cage.
will be engineered along with my flip front and turbo conversion :wink:
PostPosted: Tue Nov 01, 2005 11:42 am
nice...i really cant be bothered installing it myself though...although it is about $1000 cheaper...might have to look into it...
Bling me up Scotty!
PostPosted: Tue Nov 01, 2005 11:49 am
one last Q...should i paint before or after i get the cage installed?
Bling me up Scotty!
PostPosted: Tue Nov 01, 2005 1:28 pm
paint the cage or the car? :?
depends.. if your talking about the cage.. you coing bolt in? or weld in? or both.. if its been welded in the car you will need to paint it in the car...
if all bolt in. then paint first then bolt into the car. :)
Curly wrote:
I was under the impression that as long as they don't inpead your fast exit from the car, that DOT would not worry about them.
In Vic, intrusion bars are allowable - BUT, the last time I checked it out, they had to be no higher than the seat cushion so as not to impede on entry or egress.
This was my understanding as well for Queensland.
Basically if you find someone willing to put a blue plate (engineering Approval) on the car then Main Roads were happy....not their problem anymore :shock:
Minimad
You can take the boy out of the racer.........but not the racer out of the boy!
PostPosted: Tue Nov 01, 2005 1:29 pm
Minimad
corruption++
Bling me up Scotty!
PostPosted: Tue Nov 01, 2005 1:30 pm
paint the car...i was gonna get the cage painted at the same time...although i dont really care what color the cage is as it will be covered in pads anyway...as long as it doesnt rust i am happy with any color..i would prefer bolt-in coz its removeable...as long as the safety is comparable :)
Bling me up Scotty!
PostPosted: Thu Nov 03, 2005 10:35 am
Minimad
Queensland Transport Code of Practice - Light Motor Vehicles
Section LH - 1.2.1
The roll over protection structure must not obscure front seat access nor encroach upon the area occupied by the driver or front seat passenger. Horizontal braces alongside front seats are not acceptable.
There it is in black & white (well, blue & white :D ). If someone were to blue plate your cage like that then they are liable. I doubt very much that you would find someone willing to do it regardless of bribes.
As mentioned before, if you really want them for the track make them bolt on.
PostPosted: Thu Nov 03, 2005 12:14 pm
thats more or less the impression i was given by the 3 pplz i chatted to about this...
Bling me up Scotty!
PostPosted: Thu Nov 03, 2005 10:39 pm
Mine arn't 'horizontal' :lol: Sort of sloped down at the front. I have seen a few of the minis around that are road registered that have side intrsusion bars that are welded in.
No figure :shock:
Minimad
PostPosted: Fri Nov 04, 2005 8:34 am
No figure :shock:
Minimad
they could have had them welded after it was registered...
Bling me up Scotty!
Users browsing this forum: No registered users and 24 guests
