Late 70s VW Golf oil filter screws straight onto a Mini, it's the same diameter but longer..
excerpt from Todd Miller's AustinAmerica US site-
"Because of my experience with German cars, I have always used German filters. The filters made by Bosch, Mann and Mahle are of excellent quality. The ones that I use fit the VW gasoline engined Rabbit/Golf/Jetta/Scirocco/Fox/Quantum/Pickup, etc. from '75 on. The Bosch part number is 72150. This filter is about twice as long as the stock sized filter and just barely fits due to the location of the reverse light switch on the manual transmission cars. But, with a little finese it goes right on. When using these larger filters, remember to check your dipstick after the initial start-up because the filter holds more oil (about 1/2qt.)."
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
