It is currently Sun Jun 29, 2025 2:14 am
PostPosted: Sun Jul 17, 2005 4:34 pm
yeah for sure, but you get the exact pistons for the job not some cheap fix that isn't really gana be up to the task... i guess theres something out there that can be a compromise :)
Hmmmmm..... Jennifer Garner
PostPosted: Sun Jul 17, 2005 5:21 pm
Yea well, my cast hepolites seem to be holding up to the job...
18,000 Force-fed miles....
Weak point has been head gaskets.... all that changes today.. i can now use the BK450 "turbo" gaskets....
I'm not a big believer that "if it has a turbo, it has to have forged pistons"
for me, its what works.. and the cast hepolite 998 piston seems to be doing the job so far....
J
 Post subject: a
PostPosted: Sun Jul 17, 2005 5:30 pm
i also so believe forged arnt always needed if a car is setup properly. forged only really withstand detonation from what ive heard. i'm not one for buying something on brand name so i can place a sticker on the side.
PostPosted: Sun Jul 17, 2005 5:51 pm
Downside of forged ones is you need to run more clearance, as they expand more due to the alloy used.
And, they do wear out faster.
I had forged Mahle flat tops in the last 1310 motor. One day at Wakefield Pk one got just a little hot, and seized... :cry:
But, I still drove it 120 miles to home... with `single cylinder piston slap'... :oops:
I'm now running Hypatec cast ones. Good copy of a Hepolite 21253 type cast piston, but stronger. :wink:
<edit> for KC's thoughts on the cast vs forged debate, see here-
http://www.minimania.com/web/SCatagory/ ... ticleV.cfm
