It is currently Tue Jun 24, 2025 11:22 am
 Post subject: 4AGE into clubman
PostPosted: Wed Jul 14, 2010 7:54 pm
Hey,
I just had a quick look on here but are there any 4AGE powered minis getting around?
I know that i may be better of going 4EFTE but i like the idea of NA engines.
Would it be 'hard' to put the age into a clubman?
Im wanting to slowly work on an engine project for the mini over the next 2 years or so and am just having a look at options.
Thanks Blake
PostPosted: Wed Jul 14, 2010 8:13 pm
The subframe will be just as hard as in a roundy but as far as I can see it isn't an extremely hard job. I think if you can weld and grind you can do a conversion.
PostPosted: Wed Jul 14, 2010 8:18 pm
yeh well me metalwork skills arent to bad.
Im a little concerned about how much of the engine bay would need cutting away as i dont want to chop the car up to much.
Thanks Blake
PostPosted: Thu Jul 15, 2010 12:32 am
http://www.16vminiclub.com/forums/showt ... light=4age
PostPosted: Thu Jul 15, 2010 7:45 am
I think from memory that are too wide.
Not ever having measured one myself, i think they are over 900mm wide, while the 4EFTE sits in at around 840mm.
PostPosted: Thu Jul 15, 2010 8:43 am
Thanks for the replys.
Ive heard they are wide but ive seen a few on the 16v mini club forums that look like they havent had the track altered.
im going to go find me a 4age a take a measuring tape with me.
PostPosted: Thu Jul 15, 2010 4:39 pm
ive found some dimensions for the 4age but dont know how reliable they are but:
Wide = 860mm
High = 590mm
Im still going out to find one to double check this size but if it is only 860mm wide it should be alright
PostPosted: Fri Jul 16, 2010 2:33 pm
Why not use a 5efe? Its exactly the same size block as a 4efte/4efe, even down to mountings and gearbox. The main difference being a different sized flywheel.
Theyll bolt into the same subframes and use all of the same ancillaries.
Simplify and add lightness
PostPosted: Fri Jul 16, 2010 2:43 pm
um i thought about the 5efe but yeh i thought the 4age would be a better engine choice for N/A
PostPosted: Fri Jul 16, 2010 3:46 pm
http://www.ausmini.com/forums/viewtopic ... e&start=15
http://www.16vminiclub.com/forums/showt ... t=4age+20v
Here are a couple of pics of my 4age Mini I built in the UK and imported to Oz.
It obviously has wider track but that was only to get it into a standard length round nose.
From experience I thknk that it is possible in a clubman without changing the track.
Good Luck
Rich
1 1969 Austin Mini Cooper
1 20v 4age motor
1 Huuuuuuuuge Grin!!!
PostPosted: Fri Jul 16, 2010 3:58 pm
Hey Rich,
Yeh i have seen your car and it looks awesome but this is what is making me wondering if i would need to alter the track. Do you have a build thread anywhere?
Do you have some sizes of the engine? im assuming the 20v is the same size as the 16v (which is what i am looking at doing)
Thanks Blake
PostPosted: Sat Jul 17, 2010 8:52 pm
Sorry, No build thread! But if you look on the 16v Mini club site then there are at least 2 that you can look at. One from Dazzler and one from Spag. Both are 16v builds.
The width of engine & box is about 890 - 900mm which is about the max you can do.
You can definately do it in a clubman fairly easily without widening the track. :)
1 20v 4age motor
PostPosted: Sat Jul 17, 2010 8:54 pm
Is that width with a 6 speed transmission or with a 5 speed? I 'think' the 5 speeds from the 16Vs are a bit shorter?
PostPosted: Sat Jul 17, 2010 9:17 pm
Thanks Rich, Yeh ive had a read through all the threads on 16vminiclub.
MMmM i found somewhere that the 4age 16v was only 860 wide which makes it about 20mm longer than the 4efte but i dont know how reliable the info is. I think i will have o find one and measure it.
Im going to have a chat to an engineer over the next few weeks and see what they say about it.
Thanks Blake
PostPosted: Sun Jul 18, 2010 1:06 pm
It seems from the 16vMini forum that someone in South Africa is producing a subframe to fit this engine into a clubby.
I would really like to fit one of these engines in a Mini someday. They go well in stock form, are bombproof reliable and there's elevnty-billion aftermarket bits for them.
I have a 4AGE in my MR2. Might have to run out with a tape measure....
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
