It is currently Fri Jun 27, 2025 7:07 pm
 Post subject: GTi Manifolds
PostPosted: Mon Jun 08, 2009 11:28 am
http://www.treadstoneperformance.com/pr ... o+Manifold
Has anyone used one of these? and do you reckon it would fit in a clubman?
PostPosted: Mon Jun 08, 2009 11:51 am
No, haven't used one.
Doubt it would fit without a serious bonnet hump, as the G13b is already quite tall in the mini bay.
PostPosted: Wed Jun 10, 2009 11:18 pm
First time I've seen this manifold with top mount turbo
The manifold looks like it could fit, but the turbo will probably be too high
& hit the slam panel & bonnet
Blue
Keep shiny side up
PostPosted: Fri Jun 12, 2009 5:28 pm
Blue
Sorry to correct you, but it's not a top mount. What you can see on top is where the wastegate goes if you use one, or it can be blanked off.
PostPosted: Mon Jun 15, 2009 1:06 pm
[/quote]
Sorry to correct you, but it's not a top mount. What you can see on top is where the wastegate goes if you use one, or it can be blanked off.[/quote]
Ummmmm, do'nt know, may not fit
Blue
Keep shiny side up
