It is currently Tue Jun 24, 2025 10:14 am
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Mon Dec 06, 2010 11:21 am
'77 clubby van wrote:
It would be cool to have the sound, but to tell you the truth those figues don't impress me that much. :?
161 hp @ 7800 & 162 Nm @ 4500 for an expensive one off engine which sounds really cool and no one else has....
Vs
133 hp @ 6400 & 157 Nm @ 4800 for a cheap, standard 4efte which is easily upgradable with cheap parts with toyota reliability.
It does sound good though! 8)
You can't really compare a turbo to an NA there!!!
PostPosted: Mon Dec 06, 2010 8:20 pm
6-Bolt mains and linerless bores - love it!!!
This thing would absolutely haul ass in a mini....
PostPosted: Tue Dec 07, 2010 4:31 am
But like most V4s they vibrate badly. But these vibrate more than most. :lol: (maybe nearly as bad as a Harley.)
There's a world of difference between a V4 and a harley. Harleys vibrate because the angle between the cylinders is 45 degrees. Ducatis (also V twins) don't vibrate because the angle is 90 degrees. Japanese engineers couldn't bring themselves to build an engine as inherently bad as a HD motor, so the crankpins in my M50 (800cc v twin) are offset; it has a solid mounted motor and barely vibrates at all. My VFR750 (v four engine) was smooth as silk.
PostPosted: Tue Dec 07, 2010 10:18 am
This space for rent
Lancia knew a thing or two about V4's too.. and their were good motors.
PostPosted: Wed Dec 08, 2010 7:16 pm
There's a world of difference between a V4 and a Harley. Harleys vibrate because the angle between the cylinders is 45 degrees. Ducatis (also V twins) don't vibrate because the angle is 90 degrees. Japanese engineers couldn't bring themselves to build an engine as inherently bad as a HD motor, so the crankpins in my M50 (800cc v twin) are offset; it has a solid mounted motor and barely vibrates at all. My VFR750 (v four engine) was smooth as silk.
Honda found out the best angle in terms of comactness and anti-vibration is actually 52 degrees. I think all Honda V's, no matter whether they are V-Twin or V4, are 52 degress?
Tricky
PostPosted: Wed Dec 08, 2010 8:41 pm
hmm thats a good alternative to a bike engine for a rwd sports sedan mini!
Potato
PostPosted: Wed Dec 08, 2010 9:00 pm
Tricky,
According to the great Australian engineer Phil Irving, who designed the Repco V8 (also wrote Tuning for Speed, and other books) a 90° V twin can have perfect primary balance. You just counterweight all the reciprocation component of 1 piston and rod, and none of the other. Then the forces balance each other out. Of course, the firing intervals are way uneven, but a Ducati in full song does sound great, hey!
Most V2s of lesser angles had it to save space, or for some other reason than balance.
PostPosted: Thu Dec 09, 2010 6:34 pm
Hey Doc,
Yep, you are 100% correct. A 90 degree twin (or mutliple thereof) is the easiest in terms of engineering out harmonic vibration and ensuring perfect primary balance.
Honda only went to the 52 degree V-Twin becuase it was a lot more compact - and it was only for that reason. I think they treied 75 degress, 60 degrees etc and then finally settled on 52 degrees.
And yes, nothing like a 90 degree Ducati at full song - love the desmodromic valve operation purring at 9000rpm!!! You Doc, have excellent taste Sir!
Tricky
PostPosted: Thu Dec 09, 2010 6:39 pm
Tricky,
So what was the angle of the HRD Vincent V twin that Phil Irving designed? (a lot less than 90°) :lol:
The problem with a lot of motors is not primary balance, it is secondary balance. The V4 chev speedway motor has bad secondary balance.
Comfort is not usually a high priority in speedway. :lol:
PostPosted: Thu Dec 09, 2010 8:46 pm
OT but I was just reading one of Phil Irving's books the other week. What a legend - I'll dig up some quotes. He "accidentally" designed his V twin when two sketches of his inline engine fell on top of one another, overlapping to form the V shape!
the internet wrote:
Like Audrey Hepburn, almost everybody loves the Mini. The only people who didn't love the Mini were pathetic, empty people.
PostPosted: Thu Dec 09, 2010 9:38 pm
How hard would it be to cut a V6 or V8 down yourself?
A 3.8L V6 commy will give you a 2533cc V4.....just a spur of the moment idea :roll:
But seriously how hard is it to cut a engine down and what would you need to look for?
PostPosted: Thu Dec 09, 2010 9:42 pm
why cut one down when you can buy a proper speedway one for 7 or 8 grand
Potato
PostPosted: Tue Dec 14, 2010 1:54 pm
We used to have a V4 Ford Corsair 2000e. Not all V4's are a good thing.
Same motor was used in the Capri 2000GT, and of course in a lesser form in the early Transit Vans.
Dicko
PostPosted: Tue Dec 14, 2010 6:53 pm
Haha, we used to have a V4 transit van. That thing was hilarious. Used to hate going in it as a kid cause it was ex-spastic society pale blue and you could still make out where dad had pulled the signs off. Later on when I drove it I used to love it, high up truck driving position, revving the crap out of the V4 and going nowhere. Fun stuff. Think we sold it for $50 to the kids from round the corner.
PostPosted: Tue Dec 14, 2010 8:47 pm
There have been some very good V4s in this world, and also some very bad ones. That Ford V4 was the latter. :lol:
