It is currently Sun Jul 13, 2025 4:05 am
 Post subject: door pocket trim 1970
PostPosted: Thu Dec 20, 2018 9:51 am
There seems to be different opinions on pocket trim ,Which way do the long folds go ?
Allen
PostPosted: Thu Dec 20, 2018 10:34 am
Are you talking about the door card trim?
PostPosted: Thu Dec 20, 2018 11:51 am
OR the pocket liner? (shown under my door card)
Nick
PostPosted: Thu Dec 20, 2018 1:38 pm
the pocket liner at the bottom of the door
I've got the long fold along the side opposite the door trim (ie along the red line below)... but that's how I found it on mine, and in my mind it doesn't make sense going the other way...
PostPosted: Thu Dec 20, 2018 1:57 pm
Mine is as (ffff)fred's, and the little flappy bits sit on those brackets.
Nick
PostPosted: Thu Dec 20, 2018 4:09 pm
Allen
On my '70 S, (and mini K), there are 2 narrow wings, about the same width, along each side of the main bottom section. One wing turns up and the other turns down. See the diagram.
One of the photos of a clubman door trim has one much wider side - it might be to replace the felt-backed vinyl that was glued to the inside of the door pocket of earlier minis?
