It is currently Tue Jul 22, 2025 3:08 am
 Post subject: Diff Preload
PostPosted: Wed Mar 22, 2017 7:47 pm
I am setting up the diff preload and find I need extra shims to get the pre-load - 4thou for thrust bearings.
I suspect the new gaskets are thicker than the old ones, and I am short on shims.
Any issues leaving the side gaskets out and use RTV sealant instead?
 Post subject: Re: Diff Preload
PostPosted: Thu Mar 23, 2017 5:32 am
My car has no side gaskets and doesn't leak there. But don't use RTV, use an anaerobic flange sealant designed for this. Loctite 515 or 518.
PostPosted: Thu Mar 23, 2017 11:52 am
just buy some shims?
....you just lost him his insurance bonus!
997
PostPosted: Mon Mar 27, 2017 6:44 pm
I've read that Rover dropped the gaskets in later years and just used sealant.
