It is currently Wed Jul 23, 2025 10:39 am
PostPosted: Mon Feb 06, 2017 5:43 pm
Hi all,
Long time reader, first time poster. I used the search function to no avail :(
I have a 65 Morris mini that I want get a full body respray on. I want to know if any of you are Canberrans and can recommend a panel beater/spray painter.
Thanks in advance!
PostPosted: Thu Feb 09, 2017 6:42 pm
Well,
I've booked it in for a bare metal respray. I guess I will be the guinea pig in this situation and hopefully by this time next year I'll have a sweet new paint job.
Can anyone shed some light on the best process here?
I'm thinking:
1. Take everything off/out (nearly finished this) and give the panel beater a bare shell
2. Get it to a primed stage on the outside and finished on the inside (including engine bay)
3. Subframes/running gear back on
4. Interior/loom back in
5. Finish the exterior paint work
6. Windows back in
7. Engine back in
8. Bright work back on
With a whole bunch of smaller steps in between... :D
PostPosted: Sat Feb 11, 2017 8:00 am
Sounds about right. I would consider putting the engine in when you put the subframes in but everyone is different. Good luck:)
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Sat Feb 11, 2017 8:14 am
A good endless chain (chain block) lets you drop the engine into the subframe with millimetre accuracy/positioning and rate of descent, more-so than trying to manhandle the body onto a awaiting engine/subframe.
PostPosted: Sat Feb 11, 2017 1:49 pm
I meant more so putting the engine in without worrying about scratching freshly painted guards when you lean over them. Engine in the top or through the bottom doesn't worry me either way!
5/72 Clubman Gt
Users browsing this forum: wild_willy and 112 guests
