It is currently Wed Jul 23, 2025 8:44 pm
PostPosted: Sun Feb 05, 2017 3:23 pm
My (relatively new) Smiths classic temperature gauge seems to be over-reading at 110C, whereas the electronic Engine Guardian which measures the temp of the actual engine block via a sensor mounted onto a thermo bolt has it at 78C. The Smiths gauge usually sits within 5 degrees of the latter.
I think the voltage stabiliser may be stuffed - the multimeter is showing 12 volts at the B post and 11.49 at the I posts. They're supposed to push out only 10 volts at the I posts.
I have a bin full of these things that I've collected over the years and they've all failed. I believe there are now more modern semi-conductor types available that do the same job and are far more reliable such as
http://www.ebay.co.uk/itm/Semiconductor ... 1881270442
Is anyone local doing something similar, I definitely don't want another original bi-metal Smiths one to add to the collection.
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Sun Feb 05, 2017 3:30 pm
Try Tony, aka Convertible Mini.
He is an auto sparky that specialises in Minis.
PostPosted: Sun Feb 05, 2017 5:23 pm
Don't forget that if its a new sensor, they can read high as well... There are 2 available one reads really low, and the other reads a few deg C over I believe... I have tried both, and settled on the one that reads a bit high.. mine sits at the N mark at 80 Deg mark..
Cheers Brett
PostPosted: Sun Feb 05, 2017 5:48 pm
PM wombat, he makes em up and they work good.
PostPosted: Sun Feb 05, 2017 11:11 pm
Yep. +1 for Wombats voltage stabilisers!
Don't listen to what I am saying... just understand what I mean.
PostPosted: Wed Feb 08, 2017 8:10 pm
I also have these Voltage stabilizers in Electronic in stock.
"Let us remove your "SHORTS"
PostPosted: Fri Feb 10, 2017 2:09 pm
The original type are electromechanical. They have a bi-metallic strip inside them which opens and closes their output. They will only ever output either the battery voltage (12.7V or whatever) or nothing. By switching on and off they are meant to average out at 10V. They also probably need a certain amount of load on them to work, so just testing them with a digital multimeter won't tell you anything.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Fri Feb 10, 2017 3:06 pm
The electronic stabilizers make even the old smiths gauges surprisingly consistent and accurate.
Users browsing this forum: watsupskip and 93 guests
