Lillee wrote:
I don't think you need to go that drastic to get firmer pedal feel. Back brakes cylinder size don't have much of an effect to higher pedal, lots of other stuff does. Suggest you look at those first. I recently overhauled 90% of the brakes on my car, every little bit counts. This is what I did and I have excellent pedal feel:
- New master cylinder (You can rekit yours, but my tin tank broke it's lid screw part)
- Replace the rear adjuster screws and wedges <--- this made the biggest single difference other than the MC change
- Replaced front and rear brake hoses <--- this is important, they do internally bulge apparently and give you bad pedal feel
- Replace front caliper seals, better still just rebuild the front calipers
- Replace clevis pin and generally get rid of all play in the pedal
- Change to Green Stuff pads, I had black stuffs and the Greens are superior bite and fade much less
- Bleed the system properly... There are many ways to do this and the single best way I find is still to have someone step on the pedal method
- Last but not least, check and replace the rear slaves, check the drum wear and shoe wear, adjust them properly with the new wedges and adjuster screws
If everything is in tip top shape, you should have excellent brakes. Going to bigger rear wheel cylinders is sort of trying to lipstick on a pig as the old saying goes.
If after all this you are still dissatisfied with pedal feel then it's time to get a booster!
Basically I have done all of the above except for the booster. Been good for 30 years, just want a better pedal. Everything has been replaced, even 3/4 rear cylinders. Never had a problem with locking up, but may replace these with 5/8. The limiting valve is original, appears to be ok, should I replace this anyway. Had pressure bled the system, and the good old pump up, hold, foot to the floor, bleed method, so definitely no air in the system.
Thanks everyone for replying so quickly. Very much appreciated for your expert advise.
