It is currently Sun Jul 27, 2025 6:58 am
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
PostPosted: Mon Oct 24, 2016 7:52 pm
My deluxe has had disc brakes with no power booster for the past 30 years or so. Stops well but has always had a lower than normal pedal when pressed. It still has the standard 3/4 inch rear wheel cylinders. If I go to 5/8th wheel cylinders, wiil I get a better pedal. Also will these fit the backing plates or is a modification required.
Thanks in advance.
PostPosted: Mon Oct 24, 2016 9:21 pm
I don't think you need to go that drastic to get firmer pedal feel. Back brakes cylinder size don't have much of an effect to higher pedal, lots of other stuff does. Suggest you look at those first. I recently overhauled 90% of the brakes on my car, every little bit counts. This is what I did and I have excellent pedal feel:
- New master cylinder (You can rekit yours, but my tin tank broke it's lid screw part)
- Replace the rear adjuster screws and wedges <--- this made the biggest single difference other than the MC change
- Replaced front and rear brake hoses <--- this is important, they do internally bulge apparently and give you bad pedal feel
- Replace front caliper seals, better still just rebuild the front calipers
- Replace clevis pin and generally get rid of all play in the pedal
- Change to Green Stuff pads, I had black stuffs and the Greens are superior bite and fade much less
- Bleed the system properly... There are many ways to do this and the single best way I find is still to have someone step on the pedal method
- Last but not least, check and replace the rear slaves, check the drum wear and shoe wear, adjust them properly with the new wedges and adjuster screws
If everything is in tip top shape, you should have excellent brakes. Going to bigger rear wheel cylinders is sort of trying to lipstick on a pig as the old saying goes.
If after all this you are still dissatisfied with pedal feel then it's time to get a booster!
PostPosted: Mon Oct 24, 2016 9:30 pm
I had 3/4 rear cylinders on Barney with S front brakes and no booster. After a major drama on a freeway in the wet at 110kmh (rear wheels locked then car weaved during heavy braking)) I fitted 5/8" rears.
That's the reason the Cooper S had 5/8" rear cylinders, SAFETY. Not to get a firm pedal.
The 5/8 cylinders have the dowel pin in the other end compared to 3/4 ones. You either need to re-drill the backing plate or do what I did- drill another 5/32" hole in the cylinder and move the pin. However if it is an S, the backplate holes are correct already.
PostPosted: Mon Oct 24, 2016 9:43 pm
+1 - spun in the wet and ended up facing the traffic
PostPosted: Mon Oct 24, 2016 9:55 pm
+1 - may have contributed to a written off MK2 S and nearly my life...
PostPosted: Tue Oct 25, 2016 7:12 am
Not sure I understand what is going on here. The cooper S slave is a 5/8 bore and the standard one is a 3/4 bore which is equivalent to a 6/8 bore. The Master Cyl emits a said volume of fluid. In a larger bore (the 3/4 one) it requires more fluid to move the pistons of the slave outwards due to the increased volume of the slave cylinder. Therefore you need to depress the pedal further in order to actuate the slave to the same distance as that of the smaller diameter 5/8 slaves. If this is the case with fluid dynamics then yes switching to a smaller diameter slave will require less pedal travel to activate the rear shoes. You would be more likely to lock a rear wheel with a small cylinder than a larger one. You can apply more pressure and better braking affect on the rear wheels with the 5/8 cylinder.
There is no doubt that changing to the 5/8 cylinder WILL reduce pedal travel.
Why you guys are locking rear wheels with 3/4 slaves is anybodies guess, but I would say it is more likely because of a lack of maintenance and your rear drums are out of round. Somebody please correct me if I am wrong.
Greg
1962 Mini Speed sports sedan
PostPosted: Tue Oct 25, 2016 7:29 am
Bigger cylinder has more surface area, force at shoes = pressure x area. So brakes lock with less pedal pressure.
PostPosted: Tue Oct 25, 2016 7:31 am
Greg
Hopefully people will read this and try to understand before arguing with you!!!
After careful consideration I have to admit that my initial thoughts on this where incorrect :(
The force (in pounds) exerted by the wheel cylinder on the brake shoes is line pressure (pounds per square inch) times the area of the piston in the cylinder (square inches). More square inches (meaning a larger piston), more pounds of force.
Dave
PostPosted: Tue Oct 25, 2016 7:34 am
Kevin,
Are you kidding. Would you like me to do the maths for you?
Sorry that was harsh, p1v1/t1 equals p2v2/t2 given temp is constant the pressure is inversely proportional to the vol.
PostPosted: Tue Oct 25, 2016 7:58 am
The S brakes were fitted with a lower pressure limit valve (softer spring) & smaller rear cyls simply to help stop the rear brakes locking up (IE: to make them work "less" effectively)
this "combination" is perfect when discs are fitted to the front,
the factory did their job right
"IF" you still have large rear cyls & the std "mini" limit valve spring, you "WILL" have locking rear brakes with discs fitted on the front, especially dangerous in the wet
simple as that !!!
If you have a low peddle, then you have an adjustment issue of some sort,,, shoe or pad travel is exsessive for some reason
if you have a "spongey" peddle, then you have air in the system (generally) or a bend brake pad or swollen/guey hoses etc
if you have a low & spongey peddle, then you have a combination of all of the above
again---> simple as that
there are some people who have fitted the larger master cyl (.75)
& this will give a much higher, firmer peddle, when everything else is perfect
but then more peddle pressure is needed.
edit--> but to answer your question, yes fitting the smaller rear cyls will give a slight increase in active peddle height, provided everything else is in perfect working order, but it will be barely noticeable.
one thing people often forget about is the amount of movement the rear limit valve piston has, this does creat slight bit of peddle travel depressing the spring/piston inside it, quite often heard & felt.
PostPosted: Tue Oct 25, 2016 9:02 am
Basically I have done all of the above except for the booster. Been good for 30 years, just want a better pedal. Everything has been replaced, even 3/4 rear cylinders. Never had a problem with locking up, but may replace these with 5/8. The limiting valve is original, appears to be ok, should I replace this anyway. Had pressure bled the system, and the good old pump up, hold, foot to the floor, bleed method, so definitely no air in the system.
Thanks everyone for replying so quickly. Very much appreciated for your expert advise.
PostPosted: Tue Oct 25, 2016 9:59 am
Kevin,
Sorry Greg but Doc's right (Pascal's Law for fluids). You've used Boyle's Law for gases...
Rod.
______________________________
'63 Morris 850 (Old Secondhand CAR)
PostPosted: Tue Oct 25, 2016 10:28 am
Ah, the old PV=nRT rule. R=8.31, n= number of moles, T=temp, P and V pressure and volume.
I remember from form 6 Chemistry 1979, yikes! I forgot how bloody old I'm getting and I thought my memory was worse than that!
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Tue Oct 25, 2016 3:50 pm
Oscar wrote:
Kevin,
Aye, this is an incompressible fluid exerting a force on an area so the Boyle's law (adiabatic thermodynamic applications) does not apply. Temperature has nothing to do with force applied as you say, but neither does the volume! Simple pressure applied to area problem.
The volume only determines the amount of pedal movement vs piston movement, not the force applied.
michael
PostPosted: Tue Oct 25, 2016 4:55 pm
Love this thread.
