It is currently Tue Jul 15, 2025 2:00 pm
PostPosted: Thu May 28, 2015 1:38 pm
The diff from my 1968 Deluxe is being checked whilst the engine/gearbox is out for the repainting of the vehicle. Upon opening up the diff just now and seeing what's what, two things stand out. Firstly only one half-shaft fibre thrust washer (BTA101) is present. That's easy to fix, but it does seem it wasn't included in the assembly 47 years ago. The second issue concerns the diff centre thrust block (BTA154) which seems to have some considerable end play, to the extent of 2 - 3 millimetres. Is this excessive, and worrying?
Should it be replaced by one of greater length. Can anyone measure a new one to determine the as-made length. I do have some used spares in assembled diffs, so what would the acceptable minimum length be? Many thanks in anticipation.
PostPosted: Thu May 28, 2015 2:02 pm
The thrust blocks all have a bit of end play. It is exaggerated by wear in the spider gears' copper washers, and the hemisphere where they sit.
The other fibre washer has probably disintegrated. One problem with new washers is they are often too thick, and the diff locks up when assembled to the crown wheel. It's because the aftermarket washers are thicker.... :twisted:
I find an easy way out is linish a few thou off one or both of the side shafts where they touch the block. Gives more clearance.
BTW I hear Rovers don't have a thrust block, it got deleted. Dunno why.... perhaps they decided it really does nothing.
[edit] I would fit new spider gears and a competition shaft. Do NOT buy the cheapest ones you find, Quality costs money.
PostPosted: Sat May 30, 2015 12:43 pm
The Mini King
[quote="drmini in aust"]The thrust blocks all have a bit of end play. It is exaggerated by wear in the spider gears' copper washers, and the hemisphere where they sit.
[edit] I would fit new spider gears and a competition shaft. Do NOT buy the cheapest ones you find, Quality costs money.[/quote]
As You Know Kev, There Are Some Mini part suppliers that do sell quality items at discounted prices, It is possible to buy a kit that contains High quality Diff Pin 2 Planet ( Spider ) Gears 2 Thrust washers & a locking pin For Around $150.00
PostPosted: Tue Mar 20, 2018 3:06 pm
Does anyone have the dimensions of said thrust block BTA154?
PostPosted: Tue Mar 20, 2018 3:57 pm
Here you go, they are listed as being optional when using the DAM6027 diff cage with the static thrust washers
http://www.somerfordmini.co.uk/eshop/in ... age&id=156
PostPosted: Tue Mar 20, 2018 7:07 pm
i've never seen a Rover diff without the thrust block here in Germany. and i have rebuild one or another
Rover 214 atm ....
