It is currently Tue Aug 05, 2025 5:54 pm
PostPosted: Mon Aug 25, 2014 4:50 pm
Pleeeeease, someone say yes.
I spent ages trying to get the old ones off :roll:
What a bugger of a spot to get at, takes the biscuit for the most awkward spot on the little beast. :evil:
PostPosted: Mon Aug 25, 2014 5:23 pm
I good quality slim line spanner and one ratchet spanner and some crc usually does the trick
PostPosted: Mon Aug 25, 2014 5:33 pm
Thats exactly what I did use, just such a sod of a spot to get at.
PostPosted: Mon Aug 25, 2014 6:40 pm
You didn't lose the little brass shims did you ?
Cheers, Ian
PostPosted: Tue Aug 26, 2014 10:32 am
Cheers, Ian
Thanks I'll double check, thought they were only fitted on older cars?
Did find a very thin white plastic one but wasn't sure it was from the hinge mount.
