gafmo wrote:
Changed the Points and Candencer. Checked Plugs, Leads, Coil and Cap but they were only 3 months old. Any idea's
Wow you have chased through a lot of areas, unfortunately, when doing that you can introduce new faults that might add to the original.
Did you clean the new points with a solvent before you put them in? Go back an carefully check that all the plug leads are correctly inserted in the dissy cap and are gripping the sparkers etc
The fact that fuel is getting to the carb is good, but, is the new fuel pump pulsing fuel? I tend to look at new things introduced in these situations. Do you know someone you could temporarily borrow another fuel pump off? if so - try that and if it fixes the problem .....well....voila!!
Good luck!!
