It is currently Fri Aug 22, 2025 2:51 pm
 Post subject: Info needed on this moke
PostPosted: Thu Feb 24, 2011 7:20 pm
I'm in the process of building a moke similar to this.
What I would really like is to talk to anyone that's seen it in the "steel" and can tell me anything different about the moke body.
Even better would be to talk to the guy who built the actual car.
Currently I've got my moke shell on the hoist above a Suzuki sierra chassis and drive train and it doesn't seem to be lining up as well as I was hoping :?
PostPosted: Thu Feb 24, 2011 7:33 pm
This is my build thread so far http://www.ausmini.com/forums/viewtopic.php?t=35399
From what I can see the green one has not had any mods to the firewall. It also looks like the dizzy has been moved compared to my engine.
And the rear shocks are in a different position to my chassis.
Is the chassis under the green moke a LWB sierra? what is the measurement between the hubs?
What year, make and model chassis was used?
I REALLY WANT MORE INFO PLEASE....ANYTHING :roll:
PostPosted: Thu Feb 24, 2011 7:34 pm
Are you familiar with Andy on the moke forum?
this is his build thread
He (and his father) have done the same thing, not sure if it's an identical car, but should be helpful none the less
You're so square
Baby I don't care
PostPosted: Thu Feb 24, 2011 8:07 pm
Saw same car in Wagga last year. Owner would be a member of the Riverena branch of the NSWMCC I imagine.
EDIT: pretty sure the entire chassis is custom built.
Very well built, and yes it has independent rear wheel steering.
PostPosted: Thu Feb 24, 2011 9:02 pm
Milatsmadmini
I can... thats me :)
Moke body, not alot heavy mods, essentially the body is just welded to the chassis as mentioned it does have independent rear steering, which is controlled by a tiny toggle switch under the drivers seat, obviously suspension and what not is all a custom set up. Ill ask on the Moke Forum how to get in contact if you'd like?
-Matt
PostPosted: Thu Feb 24, 2011 9:21 pm
DAM IT :evil: Looking at the others (black one and the yellow one) things are going to be a lot more difficult that imagined :( .
I might have a look at the specs of a LWB, or I'll have to extend the SWB chassis I have.
I don't want to have to have to cut the moke shell at all if I can help it.
PostPosted: Thu Feb 24, 2011 9:38 pm
Kenno, i know andy (obviously) had the same problem: Shorten the moke or lengthen the fourby.
He went with lengthening the fourby, i'm sure you could get in contact with him via the moke forum if you want first hand informantion
You're so square
Baby I don't care
PostPosted: Fri Feb 25, 2011 6:31 am
He built the moke for Mokefest at Wagga in 2009 and he may be back there
for the National Moke Muster at Easter this year.
The rear steering was by elec motor via the switch Matt mentioned so the rear wheels
can steer either way independant from the front.
I may have more photo's but you'll have to wait till I get time to find them, sorry
PostPosted: Fri Feb 25, 2011 11:03 pm
From what I can see with mine the engine needs to move forwards, maybe move the diffs towards each end and maybe extend the chassie.
Thanks for the info and some extra pics may be interesting aswell.
PostPosted: Sat Feb 26, 2011 8:27 pm
Found the photos
he did a good job as others I have seen have moved the seat back a long way
and the fire wall is moved back about a foot or so.
Users browsing this forum: No registered users and 280 guests
