It is currently Fri Jul 25, 2025 9:27 am
Post new topic Reply to topic  [ 47 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: Wed Jun 06, 2007 10:46 am
It looks like I can be coming into the possession of two 998cc motors (unknown condition at this stage) One is in a Moke the other in the back of someones garage. I'd like to end up with an automatic so don't think I'll be needing the 998's unless I can do something with them.
David L
PostPosted: Wed Jun 06, 2007 10:59 am
ausmini mod
ausmini mod
They are worthless.
Send them both to me, I am happy to help out and clear your garage :)
PostPosted: Wed Jun 06, 2007 11:01 am
usuallly worth nothing! unless someone is desperate - I've give at least 2 away, that I recall
(thanks for the regulator by the way, installed, but not tested)
 Post subject: 998
PostPosted: Wed Jun 06, 2007 11:25 am
Sweet little engine...not worthless :D
PostPosted: Wed Jun 06, 2007 11:31 am
throw in a common crank and you'd have a 2 litre v8
PostPosted: Wed Jun 06, 2007 11:47 am
Someone, someday will need one - are they complete ?? Sitting on a gearbox etc ??? If so start them and see what they are like. Its not hard to rig up a test circuit to get them running. Just have someone hold the rocker cover so it doesn't tip over while its running.
I have given a couple away to needy homes and have been happy to receive the high grade neck oil supplied in return.
PostPosted: Wed Jun 06, 2007 12:00 pm
if you can prove they run well, you can get a couple hundred for em
PostPosted: Wed Jun 06, 2007 12:57 pm
bolt two conrods together and you could have a 2-litre, Flat 8 on a mini crank :)
PostPosted: Wed Jun 06, 2007 1:05 pm
A usable 998 is always handy to have around for when you have a major breakdown in your own mini or moke etc , just something to drop in for 3 or 4 weeks till you get your engine done or whatever . Also they're good for the newer mini folks who want to play with one and learn about mini motors without pulling their own car apart , gives them something to practice performance mods on while still driving their own car (at one stagte many years ago I was swapping motors each couple of weeks to try out different ideas , just make sure they'va all got the same gearbox type and you're set ) .
Also , andbat was looking for one so give him a PM if when you get them .
PostPosted: Wed Jun 06, 2007 2:36 pm
If they are such a burden on everyone(and they are rod boxes)I will gladly take them off your hands. One persons trash is anothers treasure(and I flatly refuse to go a 1275...lol)
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Wed Jun 06, 2007 2:52 pm
Nothing wrong with a worked 998.
Last I heard Kazjims turbo, bored and stroked 998(Car now resides in QLD) is putting out over 100bhp at the wheels for the new owner.
No more Minis!......For now.
PostPosted: Wed Jun 06, 2007 5:52 pm
Not worthless, but not worthful.
Key magic number is 1275. But not everyone wants/needs the extra power, me for one would never go less than a 1275, unless I was desperate to have a car on the road, but not everyone is like me, I can see advantages, eg fuel use.
PostPosted: Wed Jun 06, 2007 6:27 pm
Hope they're not worth anything. I want one :D
Nick.
1963 Morris 850... Shell.
1986 Alfa Romeo 33 Quadrifoglio
PostPosted: Wed Jun 06, 2007 7:16 pm
115HP at the treads I hear. It's an 1152 now, and the snail and big intercooler do help somewhat.. 8)
At last count I had 4x 998s, and 3 more that have been stroked. Sadly, one of the latter threw a rod so perhaps it's worthless now. :lol:
PostPosted: Wed Jun 06, 2007 7:50 pm
yah, give me a pm if you end up getting them :D
