It is currently Mon Jul 14, 2025 11:15 pm
PostPosted: Tue Jun 05, 2007 1:45 pm
Just purchased replacement wheel cylinders and notice that next to the bleed nipple is a hole with what appears to be some sort of split sleeve sticking out a few mm. The old cylinders have the hole but are empty. The split sleeve (or whatever it is) stops the cylinder from sitting flush. Do I remove it? If not how do I get the cylinder to sit flush so the retaining clip will go in.
I've done a search on the forums but found zip on this problem.
Any advice?
TIA
Dave
PostPosted: Tue Jun 05, 2007 2:27 pm
Its a locating dowel. Keep it.
PostPosted: Tue Jun 05, 2007 3:07 pm
What does it locate into? There is no corresponding hole in the brake backing plate?
PostPosted: Tue Jun 05, 2007 3:45 pm
There should be! :D
PostPosted: Tue Jun 05, 2007 3:50 pm
Nope. Hole for the bleed nipple and one for the brake line connection. That's it. The car is a 1962 850 if that makes any difference.
PostPosted: Tue Jun 05, 2007 6:05 pm
Make a hole with a drill - The backing plate is only pressed sheet metal. It stops the cylinder moving around inside the brake drum.
