It is currently Sun Jun 22, 2025 11:32 am
 Post subject: 3D Print
PostPosted: Wed Mar 15, 2023 7:10 pm
I needed a neat solution to mount my tachometer. A quick design in Fusion 360 and off to the resin printer. It could be used for any 50mm gauge. Left or right side of the cluster.
 Post subject: Re: 3D Print
PostPosted: Wed Mar 15, 2023 8:16 pm
Very nice! I really like how people are utilising 3D printing to make or recreate parts
1963 850 - laid up
PostPosted: Wed Mar 15, 2023 8:27 pm
Nice work
PostPosted: Thu Mar 16, 2023 7:11 am
Nice work, very neat solution.
PostPosted: Thu Mar 16, 2023 7:44 am
Fantastic work, any chance you could share the file for others to print?
67 Van, 1275cc
PostPosted: Thu Mar 16, 2023 10:11 am
I need a tacho, does it work well and what is the part number?
PostPosted: Thu Mar 16, 2023 7:20 pm
I have put it up on Thingaverse.
https://www.thingiverse.com/thing:5913417
PostPosted: Thu Mar 16, 2023 7:26 pm
The tacho works ok, as does the temp and oil gauges. I chose this brand because the temp and oil gauges are electronic. Search for "Tachometer gauge 8000 RPM Speco Street 52mm 2" black 523-20"
PostPosted: Thu Mar 16, 2023 8:14 pm
Thank you.
PostPosted: Fri Mar 17, 2023 7:48 am
Champion - thanks!
67 Van, 1275cc
PostPosted: Mon Aug 28, 2023 2:54 pm
Had a friend print this for me last week, came out absolutely top notch. Thanks again!
67 Van, 1275cc
PostPosted: Mon Aug 28, 2023 5:19 pm
Nice pod.
A Speco 52mm tacho I have, the needle bounces around, not sure of the model though.
Cheers Dave.
PostPosted: Tue Aug 29, 2023 9:44 am
That looks neat I agree.
I needed a bigger tachometer so got an Autogage one. Made by autometer.
https://www.ebay.com.au/itm/164408368664
The body rotates 360° so you just screw it to the shroud.
I've had mine for years it's accurate and well damped.
Edit
And it's half the price of a Smiths.
Last edited by drmini in aust on Mon Aug 12, 2024 10:43 am, edited 1 time in total.
PostPosted: Mon Aug 12, 2024 10:02 am
Nice
1973 Clubman GT - YG2S8 1637
