It is currently Sun Jun 22, 2025 2:05 am
 Post subject: Engine test stand
PostPosted: Mon Aug 21, 2023 7:19 pm
I have seen people run an engine on the floor but I have always tested them in situ on a car.
I now need to run one and no car easily readily available (all have engines in).
Do I go to the bother of building a good solid stand or adapting something, or just run on floor.
What's everyones opinion?
Cheers Dave.
 Post subject: Re: Engine test stand
PostPosted: Mon Aug 21, 2023 7:39 pm
Run it on the floor. The last one I did I had it sitting on a motorbike jack and ran it like that.
Matt/Readspeed just uses oil drums.
Too many minis
PostPosted: Mon Aug 21, 2023 7:57 pm
On a trolley? Then you can push it around 8)
PostPosted: Mon Aug 21, 2023 9:35 pm
On the floor, or trolley if you have one. Steady as a rock.
PostPosted: Tue Aug 22, 2023 8:39 am
Thanks for the ideas and pics.
I have it on a homemade trolley but it is just sitting there and wobbles a fair bit.
I might look at adapting the trolley.
Cheers Dave.
PostPosted: Tue Aug 22, 2023 9:37 am
I have run them on the floor no problem. Just don't rev it too hard or it'll walk about,
PostPosted: Sun May 19, 2024 4:03 pm
This project was put on the back burner as I could not find the spare pot joints I have to seal the diff outputs.
I now have the pot joints so I will be cracking on with making a test stand.
Cheers Dave.
PostPosted: Sun May 19, 2024 9:40 pm
I did mine on a flat dolly but had a ratchet strap holding it as I'd hadn't done this before.
Initially I didn't have the radiator on and when it started after many attempts it still rocked and scared the you know what out of me as I thought the fan was going to hit me.
Mk 1 Cooper S 1965
If you could erase all your mistakes of the past
You would also erase the wisdom of your present
Remember the lesson not the disappointment.
Users browsing this forum: No registered users and 116 guests
