It is currently Tue Jun 24, 2025 2:38 pm
 Post subject: Exhaust sytems
PostPosted: Sun Aug 20, 2023 2:57 pm
What sort of exhaust system and extractors are people using foraximum power on a small bore with head work and a mild cam? Also what carby are people using? A weber twins etc etc
1964 smooth roof panel van
1967 Mk 1 X-Police cooper s
1970 mini k
1975 leyland
 Post subject: Re: Exhaust sytems
PostPosted: Sun Aug 20, 2023 5:14 pm
I’m using a Maniflow Freeflow manifold and twin box RC40. I haven’t tried any other combinations
For the carb I’ve tried twin HS2 and Dellorto DHLA40. My experience is the Dellorto makes more power, I’ve been using a Warneford/Redline manifold and Ramflo filter and you can squeeze it in without bulkhead modifications
Engine is an 1100 bored 080 over, RE266SS cam, GR big valve 202 head
PostPosted: Sun Aug 20, 2023 5:39 pm
And how does that go compared to other size motors/minis. I'm used to a 1275 been quite a long time since I drove a small bore. Trying to give my little brother a small sense of what to expect when his is registered.
1970 mini k
1975 leyland
PostPosted: Sun Aug 20, 2023 5:47 pm
I did a 998 screamer many years ago. HS6 SU, LCB medium bore and a warm cam. Went very well.
PostPosted: Mon Aug 21, 2023 8:19 am
I did an 1108cc 998 a few years ago with a Perry Freeflow manifold and RC40 exhaust. 40 Dellorto and 34 chokes. 266ss cam. 202 head with Cooper 998 valves. It's still going hard in mate Joe's van.
PostPosted: Mon Aug 21, 2023 7:46 pm
Mine goes really well. It’s grunty down low and goes up hills fine. I have a limiter set at 6000rpm so it doesn’t have the top end rpm of other engines
Compared to some 1275 engines I’ve driven, mine seems a bit stronger down low but doesn’t have the top end pull
PostPosted: Tue Aug 22, 2023 10:22 pm
The Vizard book has plenty of good info on systems and what they are best suited for.
;-) Pete...
____________________
1968 Deluxe 1275
1969 Deluxe 'Scruby' 998 Looking for a roof skin...
