It is currently Tue Jul 01, 2025 8:34 pm
 Post subject: Sump plug issue
PostPosted: Wed Sep 09, 2020 9:48 pm
Looks like a PO was a bit heavy handed and stripped the sump plug :(
What is the best fix, helicoil or adapter bush.
 Post subject: Re: Sump plug issue
PostPosted: Thu Sep 10, 2020 6:20 am
Adaptor bush. Because trying to helicoil it dead square to the washer surface is so hard to do.
Whereas it can be tapped and an insert fitted in the car if necessary.
You can also get tapered sump plugs for Minis which don't need a copper washer.
PM me if you want an insert fitted..
PostPosted: Thu Sep 10, 2020 7:23 pm
I guess just a bsp plug would be good too, tapered plug with some thread tape on it. you could also fit the magnet in it too.
1972 Mk3 Mini 1000, 1150cc supercharged.
https://www.ausmini.com/forums/viewtopic.php?f=3&t=95872
PostPosted: Sat Sep 26, 2020 8:07 pm
This is what it looked like at 8:30 this morning.
After a visit to the good Dr Mini aka Kevin, it looked like this by 9:30.
Thanks for your help rescuing another mini gearbox :D
PostPosted: Sun Sep 27, 2020 12:02 pm
Right choice there. I have one of Kev's adapters to cure the crack leak where someone had bashed it right on the sump plug. It is so easy to maintain a good square face on the adapter compared to the alloy of the case. Mine has never leaked again in 12 years.
PostPosted: Mon Sep 28, 2020 7:55 am
Great solution... 8)
How do you anchor the insert Doc? To stop it loosening during future oil changes...
PostPosted: Mon Sep 28, 2020 9:00 pm
Loctite 262 from memory
PostPosted: Tue Sep 29, 2020 8:21 am
Cheers Phil...I was just about to go all John McEnroe on the Doc! :lol:
PostPosted: Thu Oct 01, 2020 2:22 pm
If there was a demand for these adaptors I'd get my mate to churn a heap out on his auto lathe. But I think I've only made 5 or 6 in the last 15 years. Not a money spinner.
PostPosted: Thu Oct 01, 2020 5:24 pm
Should start a post as I would like one or two don't even know the condition of mine but think it is good idea once gear box is stripped down and once I get body work done.
PostPosted: Fri Oct 02, 2020 8:51 am
Hi Kevin
Im interested .
I have the 1300 leaking at the plug . The PO has done exactly that and munted a helicoil - slightly off and the washer doesnt sit flat .
The thread is standard .... would the adaptor work in this scenario ?
cheers mate
Simonw
Brisbane QLD
1st car - 1964 Mini Panelvan 850
Previous - 1978 Leyland LS 1275 Gold
- 1969 Mini K
PostPosted: Fri Oct 02, 2020 1:23 pm
@Simon
No. The outside thread is 3/4 UNF and the sump must be drilled and tapped. Can be done in the car if on a hoist. Put grease on the drill and tap to hold the swarf.
When finished and adaptor and plug fitted, pour 4 L of cheap oil or your last dump of sump oil in. Drain it out and it'll bring any remaining alloy swarf.
Drill size for the 3/4" unf tap is 17.5mm. 11/16" works too.
Mine has had the shank turned down to 1/2".
Not sure what diameter the outside of your 5/8 helicoil is. Screw it out a bit and measure before drilling.
PostPosted: Sat Oct 03, 2020 11:18 am
@Simon
The simple brilliance of this design is that it doesn't really matter how square the 3/4UNF thread is to the sump face, because that bit is sealed by the thread sealer. The sump plug is always guaranteed a square face on the adapter for the washer to seal against. This is why it will never leak.
Kev, if it is not a money spinner, maybe we can throw a drawing into a How To as an open source design. Then anyone anywhere with a lathe can knock one out to fix their pride and joy.
michael
PostPosted: Sat Oct 03, 2020 2:35 pm
@Michael,
I have a cad drawing from when I worked at Rheem.
See post below.
I will put it and a blog into the how-to forum tomorrow.
Last edited by drmini in aust on Sat Oct 03, 2020 7:21 pm, edited 1 time in total.
PostPosted: Sat Oct 03, 2020 2:55 pm
Ignore where it says `copper washer to seal'. No need, it's Loctited in.
Also, the title block says 1275. This mod works on any Mini box.
I can't edit this, I'm retired and now CAD illiterate.
Also, hexagonal bar is better than round to tighten it up. I used hex on the last couple.
Users browsing this forum: Bing [Bot], Goldbrocade_62 and 92 guests
