It is currently Sat Jul 19, 2025 4:10 am
 Post subject: Re: Irregular spark
PostPosted: Wed Aug 23, 2017 4:20 pm
zulu_warrior1976 wrote:
Still backfires like a mofo.
Too lean?
PostPosted: Wed Aug 23, 2017 6:03 pm
Is it misfiring sitting at idle or driving along.
PostPosted: Wed Aug 23, 2017 6:07 pm
whiteysi8876 wrote:
replace the condenser in the distributor
And the chocolates go to whiteysi8876. The condenser was the solution.
Thanks guys.
Z
Zulu...
1967 mini Cooper S
PostPosted: Wed Aug 23, 2017 10:33 pm
Some well known brands of condensers now are rubbish.
It makes more sense than ever to bin it and the points, and fit an electronic module. Less spark scatter, and the timing stays set.
PostPosted: Wed Aug 23, 2017 11:15 pm
Why am I not surprised? We had exactly the same problem in the 2015 Pork Pie Charity Run - a new condenser broke down after 2 days of hard driving, and the replacement after only one day. The third (Repco supplied) unit went the distance, and a 'spare' Repco unit was needed for another car having the same problems.
So... as drmini says...move to electronic components, at the very least.
We ran the 2017 Pork Pie Charity Run on an electronic distributor (from a Mini Metro) and it did not miss a beat over 5000km of hard driving.
'66 Mk 1 Cooper S,
'69 Mk 2 Cooper S,
'81 Leyland Mini (in New Zealand),
'78 Clubman 'Special' (track car)
PostPosted: Sat Aug 26, 2017 6:49 pm
Mini now has a balanced resistor, new condenser, new rotor, new leads, new plugs and new dizzy cap. Started like a dream but ran like a turd. Solution... was running too lean at low revs. After an SU tweak now it's back to car heaven. Just can't help but smile when I drive it!
Zulu...
1967 mini Cooper S
PostPosted: Sat Aug 26, 2017 6:51 pm
Electronic ignition will be on the next project... [FACE WITH STUCK-OUT TONGUE AND WINKING EYE]
Zulu...
1967 mini Cooper S
