It is currently Tue Jul 29, 2025 9:24 pm
PostPosted: Sun Jan 03, 2016 10:55 pm
Alexw wrote:
Has anyone has experience with these carter pumps?
I'm wary of facet pumps, heard a lot of bad things about them.
Thats the one I have. Works ok on a 45 weber. But the total length is quite long with the inline filter when fitted up under the car.
PostPosted: Sat Jan 16, 2016 2:19 pm
I ended up going with the Holley pump as in a previous post. I used the original su mounting holes in the subframe and made a bracket to suit. I didn't use the supplied filter as it was too long to fit where I wanted. I fitted a pre-filter in the boot.
Rubber dampers were sourced from some spare rocker cover grommets. Very happy and the car started first go!!
PostPosted: Sat Jan 16, 2016 2:47 pm
Good to hear, thanks for the update - I think I'll just copy that mounting bracket to mount mine too :)
PostPosted: Sat Jan 16, 2016 3:37 pm
No problem....I would do the same. :) I got the 90° fittings from Pirtek too, about 6 bucks each.
Cheers, Richard.
PostPosted: Sat Jan 16, 2016 8:44 pm
Have used an electronic facet pump on twin 1 1/4 SU's on an 1100 motor for over 20 years. Never missed a beat, never flooded the carbys, full on performance. Why bother with anything else. Thoroughly recommend.
PostPosted: Sun Jan 17, 2016 10:31 am
Ditto re facet pump, no regulator..
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Sun Jan 17, 2016 4:38 pm
I'm sure the facet pumps are great, I though I'd give this one a go as the noise level might be less as it's encapsulated in plastic.
PostPosted: Mon Jan 18, 2016 5:39 am
I had one of these carter pumps on my MGB and it used to flood the twin 1 1/2 inch SUs. I replaced it with one of my $50 'Square type pumps" and fixed the problem. 3 to 4 psi. makes more sense to use the correct low pressure pump in the first place than having the wrong one and correcting it with an unnecessary pressure regulator. Unless you like seeing these things under the bonnet for show and more things to give unnecessary trouble.
"Let us remove your "SHORTS"
PostPosted: Fri Mar 11, 2016 5:55 pm
Anyone had a Facet pump leak out of the body.
Mine looks like it's leaking from where the tags are clamped over the base.
PostPosted: Fri Mar 11, 2016 8:54 pm
I have had 2 square Facets and a square TRW on various cars over the years and never had a leaking problem. They just seem to keep working.
Users browsing this forum: diecast and 89 guests
