It is currently Wed Jun 25, 2025 6:57 pm
PostPosted: Thu Dec 15, 2022 7:54 pm
The engine steady bracket that is welded to the bulkhead on my mini 850 shell has been removed by the previous owner. I have ordered a new bracket but I need the measurements so as to be able to weld the new bracket. Many thanks.
PostPosted: Thu Dec 15, 2022 8:11 pm
Does/should it have the plate which goes under the master cylinders and is the top half of the bracket? That would at least give you the horizontal position.
Too many minis
PostPosted: Thu Dec 15, 2022 8:51 pm
Yes thanks, I have the top bracket but I need the other measurements
PostPosted: Fri Dec 16, 2022 8:33 am
Bolt the body end of the engine steady together (with its top and bottom mounts).
Bolt the top mount in place.
The bottom mount will now be exactly where it needs to be welded to the cross member...
Voila!! ..as the Froggies say :D
Cheers, Ian
PostPosted: Fri Dec 16, 2022 2:22 pm
Thanks Ian
Users browsing this forum: MINI66 and 57 guests
