It is currently Mon Jun 30, 2025 3:39 pm
 Post subject: 1275 Chamber issue
PostPosted: Thu Dec 17, 2020 8:24 pm
Hi everyone,
I picked up a head that had a gouge in the chamber, that ran slightly into the valve seat. It looked like an angle grinder or something had hit it.
I ground it down to get rid of it, but to a depth that left only a smidge of the original seat.
Could it be used if new seats were cut?
I know it would pose problems with rocker geometry etc, but I figured if I use shims under the rocker posts and Cooper S valves, maybe???
 Post subject: Re: 1275 Chamber issue
PostPosted: Thu Dec 17, 2020 8:48 pm
Just recut the seats. Or fit unleaded inserts.
PostPosted: Thu Dec 17, 2020 9:29 pm
Thanks Doc, that’s good to hear. Do you think the rocker angles etc will be workable?
PostPosted: Fri Dec 18, 2020 4:12 pm
What is the casting number on the head, near the rocker posts?
PostPosted: Fri Dec 18, 2020 4:20 pm
It’s a 12G940. (12938 or something near the thermostat)
PostPosted: Fri Dec 18, 2020 5:36 pm
OK. It's a Morris 1100S or 1300 auto head.
Just recut the seats, or get unleaded exhaust inserts fitted. Use standard 1100S valves or MK 2 S inlets if you prefer.
Shims are available to pack up the rockers if needed (usually not with a modified cam), also to pack up the springs to optimise assembled height.
