It is currently Fri Jul 04, 2025 4:44 am
 Post subject: Primary gears
PostPosted: Mon May 11, 2020 6:58 pm
I have a few primary gears and am unsure if they are 1275 or something else.
How do I determine if a primary gear is 1275 or not apart from physically sticking it on a 1275 crank?
(Are all 1275 primary gears the same... ie mk1 S, mk2 S, 1100S etc)
Brenton
 Post subject: Re: Primary gears
PostPosted: Mon May 11, 2020 7:04 pm
Brenton
Send a PM to our resident expert - Richard
Top bloke and always willing to help
PostPosted: Mon May 11, 2020 7:37 pm
The small bore ones have the same diameter bush in each end.
1275 is bigger on the engine side bearing
PostPosted: Mon May 11, 2020 7:39 pm
all 1275 crank tails are the same.
PostPosted: Mon May 11, 2020 7:44 pm
I know of three different 1275 crank tails. :mrgreen: But one of those is RWD.
PostPosted: Mon May 11, 2020 8:00 pm
So do small bore and 1275 primary gears have the same number of teeth?
PostPosted: Mon May 11, 2020 8:02 pm
yes I believe so. 998s machined will fit a 1275
PostPosted: Mon May 11, 2020 8:39 pm
There might be some information here about 1275/998 primary gears:
viewtopic.php?f=2&t=99457
PostPosted: Mon May 11, 2020 9:11 pm
Thankyou people for your replies.
