It is currently Fri Jul 18, 2025 11:33 am
 Post subject: oil cooler CS 1970
PostPosted: Sat Dec 30, 2017 7:27 pm
Just fitting gear onto engine, the clearance between oil cooler and starter motor is 4mm is that enough?
Also 2 holes above starter motor 5/16, approx. 70 mm apart what goes there ?
Thanks Allen
 Post subject: Re: oil cooler CS 1970
PostPosted: Sat Dec 30, 2017 7:42 pm
Pretty sure all is tight ,are you talking about in the transfer housing wheresolenoid would be
PostPosted: Sat Dec 30, 2017 7:46 pm
probably but the new solenoid is smaller between hole centres
PostPosted: Sat Dec 30, 2017 8:02 pm
The solenoid is screwed to a mounting plate which bolts to the housing
PostPosted: Sat Dec 30, 2017 8:58 pm
TY
PostPosted: Sun Dec 31, 2017 9:51 am
doesn't sound right.... I don't use my oil cooler anymore, and have a Gemini starter motor, but I reckon there was more clearance than that...
PostPosted: Sun Dec 31, 2017 11:20 am
Its pretty close, but doesn't touch.
PostPosted: Sun Dec 31, 2017 1:15 pm
I have a relationship problem with oil coolers so I stopped using the things. Except for originality purposes not sure if they are even necessary?
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Sun Dec 31, 2017 4:22 pm
Aren't they used in performance cars!
PostPosted: Sun Dec 31, 2017 5:25 pm
When the S came out oils was rubbish times have changed oil is much better these days
