It is currently Mon Jul 28, 2025 7:29 pm
 Post subject: Re: MK2 Cooper S Gearbox
PostPosted: Thu May 12, 2016 6:23 pm
GundyGuy wrote:
Mine has the switch and the wiring diagram shows the switch fitted
Can anyone provide solid evidence of this matter
Reverse lights came in 72.
my 12/71 GT has the switch and the wire in the front harness but no wire in the rear.
Police cars have reverse light switch. My police 71 GT has the light switch.
PostPosted: Thu May 12, 2016 6:32 pm
GundyGuy wrote:
Also an actual photo of what the serial number should look like
I will get a photo for you later tonight.
PostPosted: Thu May 12, 2016 6:44 pm
My 8/70 police S gearbox does not have any serial number stamped in the boss on the casting, as John and others have said. It does have S gears and the reversing switch on the 'box and tail lights have the extra terminals on the orange/indicator bulb holders.
I also think that my Mini K (about 7/69 - no compliance plate needed) gearbox does not have a serial number stamped on it - need to check in daylight.
Bill
PostPosted: Thu May 12, 2016 7:11 pm
Here you go.
PostPosted: Fri May 13, 2016 5:49 am
Thanks for the photos and extra info
1970 MK2 Cooper S
PostPosted: Sun May 15, 2016 1:08 pm
Is there a 22G846 cast into gearbox number as well for mk2 4 synchro or mini K remote 4 synchro remote gearbox
I know you have mentioned 22G1128
PostPosted: Sun May 15, 2016 1:26 pm
yes but it's not an "S" casing.
PostPosted: Sun May 15, 2016 1:40 pm
is 22G846 the morris mini K remote 4 synchro box
PostPosted: Sun May 15, 2016 2:29 pm
I have a little bit of info on the remote 4 syncro boxes.
22G1128 was used in Australia on the Mk2 Cooper S, Mini K/1100, Export Moke, Early Clubmans.
22G846 was used in the UK on the Cooper S, Riley Elf, Wolsely Hornet.
I have no data on Australian built cars fitted with the 22G846.
PostPosted: Sun May 15, 2016 3:41 pm
22G846 do exist here, I had one a while back.
PostPosted: Sun May 15, 2016 3:54 pm
My late 1970 SPO41 Mk2 S definitely had reverse lights, as did Greg Scott Young's camino gold 71
1962 Mini Speed sports sedan
PostPosted: Sun May 15, 2016 4:40 pm
gtogreen1969 wrote:
Here you go.
Do these numbers match the chassis number/engine number?
1970 MK2 Cooper S
PostPosted: Sun May 15, 2016 4:44 pm
Sorry but I don't have an answer on that one. The bottom doesn't as it has been fitted to a MK1 Cooper S engine.
PostPosted: Mon May 16, 2016 5:16 pm
"22G846 do exist here, I had one a while back."
I have one in Slidey.
PostPosted: Mon May 16, 2016 6:20 pm
Our How To section says - 22G846: 4-synchro, as for 22G1128 Mini K and 1098 Clubman.
viewtopic.php?f=25&t=86659
