It is currently Tue Jul 29, 2025 6:22 am
 Post subject: Removing dip stick tube
PostPosted: Sun Apr 03, 2016 1:58 pm
What's the best way to remove the dip stick tube from the block.
Does it just tap through from the underside or is it threaded in ?
Also what type of gasket glue are people using on the water pump ?
Are you best to apply it to both sides of the gasket ?
cheers all !
PostPosted: Sun Apr 03, 2016 2:01 pm
Mine sometimes comes out with the dip stick when I check the oil level
PostPosted: Sun Apr 03, 2016 2:02 pm
Yes, it is just a press fit. Sometimes less than a press as Chris has found.
PostPosted: Sun Apr 03, 2016 3:38 pm
Ok that's good to hear. I have hit it from the underside with a block of wood and hammer and it's not moved yet, will hit it a bit harder.
Any ideas about the water pump gasket fitting.
PostPosted: Sun Apr 03, 2016 6:33 pm
For the water pump any gasket sealant is fine.
[edit] When I say `gasket sealant', I don't mean silicone. I use Loctite/Permatex #3, or Loctite 515 ( a smear). Silicone is for gutters and showers, rofl.
Last edited by drmini in aust on Sun Apr 03, 2016 10:20 pm, edited 2 times in total.
PostPosted: Sun Apr 03, 2016 7:08 pm
waterpump gasket fitting? forget silicone. Aviation gasket cent is the go. The silcone if applied to liberally can come loose and block the radiator cores.
PostPosted: Sun Apr 03, 2016 8:10 pm
http://www.supercheapauto.com.au/online ... mendations
I think tk is saying this stuff which I use as well on waterpumps no matter what car it is
Its like a dark brown thick liquid with a funny smell
PostPosted: Sun Apr 03, 2016 8:15 pm
Just noticed he has a different dipstick to the Leyland engine ones
PostPosted: Sun Apr 03, 2016 8:16 pm
Yours may be plastic. They're a little bit like that.
PostPosted: Mon Apr 04, 2016 9:57 pm
My dad used Stag jointing compound 50 years ago when I was a boy.
I'm still using it and always had good results.
PostPosted: Wed Apr 06, 2016 8:33 pm
Ditto.
It's like old red lead oxide paint - excellent on parts where water can get under and corrode: like core plugs and oil gallery plugs. Hylomar (with the correct gasket) seems to work on everything.
PostPosted: Wed Apr 06, 2016 9:07 pm
It is plastic
PostPosted: Wed Apr 06, 2016 9:41 pm
This dipstick oil tube is steel. It may just have some rust holding it in tight ?
I did use Loctite aviation 3 gasket glue on both sides of the gasket (smeared) and seem to have a leak somewhere.
I don't think the gasket shifted during application because the bolts screwed in nice and easily.
PostPosted: Thu Apr 07, 2016 8:26 am
The steel one just taps out, upwards.
Even if loctited in, it will tap out.
But the plastic (nylon?) ones get brittle, are easily broken if bent at all.
PostPosted: Wed Apr 13, 2016 8:33 am
Gasket goo is all Ive used and never failed
Sent from my SM-G900I using Tapatalk
Users browsing this forum: Majestic-12 [Bot] and 84 guests
