It is currently Sat Aug 02, 2025 7:49 am
PostPosted: Sun Jan 10, 2016 6:54 am
http://www.gumtree.com.au/s-ad/forest-l ... automotive
"Let us remove your "SHORTS"
PostPosted: Sun Jan 10, 2016 7:59 am
Maybe because it's a personal import? Personal imports rules are pretty lax compared to full compliencing.
PostPosted: Sun Jan 10, 2016 11:21 pm
No. Even Personal Imports require head restraints (ADR 22). It is one of the very few they are not exempt from.
Don't listen to what I am saying... just understand what I mean.
PostPosted: Mon Jan 11, 2016 6:48 am
I would hate to read about the consequences if it is in a rear ender!
PostPosted: Mon Jan 11, 2016 7:24 am
Online
The 20th anniversary model was the 1100 special from 1979.. This car for sale has none of the correct features of the 1100. Unless maybe they did a separate 20th anniversary model for NZ?
http://www.aronline.co.uk/blogs/cars/mi ... 0-special/
The physical consequences will be the same as driving my car, not worth thinking about!
PostPosted: Mon Jan 11, 2016 3:54 pm
How was it registeered then ? if not legal?
PostPosted: Mon Jan 11, 2016 4:07 pm
Minis weren't made in Australia in 1979 so I think it would pass
I think it would be a different story if they were still being made then
A 1979 Chevrolet would pass here as well and they weren't even made here
PostPosted: Tue Jan 12, 2016 12:45 am
No, imports need to comply with the same rules as any local car had to at the same build date. The only exception is for a Personal Import which is exempt from all except seat belts, seat belt mounts, child restraint anchor points and head restraints from memory.
(And a Personal Import is not simply a car imported by a person instead of through a business, rather it is a car that has been owned and used as the Australian Citizen importers regular transport overseas for more than 12 months that is being brought back to Australia with them as part of their personal effects.)
PostPosted: Fri Jan 15, 2016 12:09 pm
I recently did a Personal Import.
As with the Mini eleven years ago, the car passed the basic safety Compliance checks; lights, horn, windscreen etc, no worries.
I has already fitted the child restraint hooks.
The only other issue that the compliancing Engineer pointed out was the headrestrainst. There is now a minimum height required between the seat squab (where yer bum is) and the top of the headrest. Simple fix was to use a short piece of alloy tube as a spacer. Car was Complianced and passed the Vic Roads gauntlet.
PostPosted: Sun Jan 17, 2016 6:05 pm
viewtopic.php?f=40&t=91562
Matts dads inported clubman wagon don't have headrests either and that's was regoed in Canberra and Qld adrs were aus wide but that could be a 71-72 model in the uk
Users browsing this forum: Bing [Bot] and 73 guests
