It is currently Sat Jul 12, 2025 2:10 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 525, 526, 527, 528, 529, 530, 531 ... 568  Next
PostPosted: Mon Dec 14, 2015 8:03 pm
jb007 wrote:
What's know carpet... where did you get it from. It looks good!
Thanks!
Knox is the brand,
I got the 'Classic Loop' in dark red
http://www.knoxautocarpets.com.au/leyla ... 1960-1978/
PostPosted: Wed Dec 30, 2015 9:46 am
We started December 1, 2015...shell had been on a rack in my garage for too many years. New full length half floors installed, new heel board installed, rod change tunnel portion welded into place, new cross member installed (modded for rod change tunnel section)...other bits dealt with...lots more to do.
You can follow the photo progress at - http://www.miniman.ca - look for Rick's Resto at bottom of project list on left...as it will be updated regularly. Slowed down a bit over the run up to Christmas. Will be back on it in the New Year.
This only affects the OZ Window Van in that the 1293cc build will go into the '62 Woody and the turbo build will be planned to go in the square nose.
PostPosted: Wed Dec 30, 2015 11:09 am
I took my car for Club plates inspection recently and the registrar pinged my 2 screw Lucas Oz tail lamp lenses for being a bit pale.
So I took them off and recoloured them with red and orange lens lacquer, they are legal again now! :)
Yes, I know you can buy new aftermarket 2 screw ones, but they go dull in 12 months I found years ago.
PostPosted: Wed Dec 30, 2015 2:45 pm
The Brick has sat neglected in the shed for well-over six weeks since given its last oil change and a general smarten-up in preparation for the 2016 season. It was on its road-tyres, the Club Permit sticker had been renewed and it was impossible to ignore any longer that hangdog look of expectation whenever the garage door was raised.
It was before most people had crawled out of bed that the pristine stillness of this early country morning was broken. The engine coughed once or twice then settled into an irregular rhythm accompanied by that cacophony of familiar mechanical noises A-series enthusiasts know so well. We crawled down the 250-metre long driveway and upon reaching the road took the down-hill option in order to give the choke-less, Weberised engine a chance to warm up before being asked to behave properly. The fuel gauge hadn't moved, so it was either broken or the tanks were empty! It's about 4km into town, mostly downhill - so with optimism and a light foot on the throttle we headed in that direction. At the servo, a chap filing at another pump wandered over to look at the Brick and he told the usual stories about having owned a Cooper S back in the 70s, but couldn't remember if it was a 1600 or 1800 version! $10 worth of 98 moved the needle a smidgen away from the E, which meant that at least the gauge was working. The cashier gave a wry smile and said,"Have a nice run". It takes a few minutes to access most competition cars and this one's no different. There's a full roll cage with intrusion bars, a high sided race seat and a 6 point harness to plug in. One feels quite self-conscious as other customers watch on curiously.
Thankfully the engine started at a twist of the key and settled at an eager idle before moving off smoothly to enjoy the empty roads of the nearby hills. The chosen route consisted of undulating, sweeping and sinuous secondary roads that allowed for enjoyment without the need to exceed the posted speed limits. The Brick behaved impeccably and reminded me of why I've owned and maintained this car since 1973 - on the right road, you wouldn't want to drive anything else :wink:
Curly
PostPosted: Wed Dec 30, 2015 3:47 pm
Was there much "wiggling adjusting" to get it to sit properly ?
PostPosted: Sat Jan 02, 2016 9:18 pm
Replaced a broken wheel stud and took it to the Monthly car meet at Bakers cottage
PostPosted: Sun Jan 03, 2016 7:15 am
Had a shed/street sale on Sat, sold a lot of mini & moke stuff and a bit of house stuff as well.
Took all the left over bits to the local tip, I now hove extra room in the shed.
PostPosted: Sun Jan 03, 2016 9:38 am
jprior2912 wrote:
Thanks!
Knox is the brand,
Hi, the carpet looks fantastic....and cheap! Was it a full set? Was there much cutting to fit?
Thanks
PostPosted: Sun Jan 03, 2016 9:24 pm
Changed a small shaft in the bottom of the gearbox. Lot of work for a busted pin. - now I have gears :-)
PostPosted: Mon Jan 04, 2016 3:05 pm
Took the mini for a drive to work today. Not much traffic about as lots of people still off work made for a pleasant drive to work.
1972 Leyland Mini Clubman
2000 Honda CBR929RR
PostPosted: Tue Jan 05, 2016 6:14 pm
Wasn't today but I've finished the new dashboard in my 76 clubby. Pretty happy with it. Very functional.
-----Better is the enemy of good-----
-1976 Yellow Devil Leyland Clubman-
-1970 Morris Mini Van - Work in progress-
PostPosted: Tue Jan 05, 2016 9:44 pm
Cooked up some extractors :D
I have a problem.. apparently
PostPosted: Tue Jan 05, 2016 10:39 pm
What a brilliant idea!
PostPosted: Wed Jan 06, 2016 10:49 am
Next time I'd probably clean the grease out of it because there's a few marks on the paint now haha :)
PostPosted: Fri Jan 08, 2016 9:03 am
Turned on the radio, adjusted the clock to the right time and had a very tuneful drive to work.
2000 Honda CBR929RR
