It is currently Sun Aug 03, 2025 3:16 am
 Post subject: Re: Increasing power
PostPosted: Sun Dec 06, 2015 4:35 pm
Just browsing different cams available. Would the GR 266 ss suit a 998 for road use?
Steve
PostPosted: Sun Dec 06, 2015 6:41 pm
Steve
Sure would, I've just put one into an 1108 (a 998 bored to 68mm).
With twin HS2s, a GR modded 202 head and an LCB it should sing nice. Rockers are refaced stock 998s with a new HD shaft.
BTW I had a Wade 104 in a 1293, even with 1.5 rockers and twin HS4s on that I was not impressed.
PostPosted: Sun Dec 06, 2015 7:00 pm
That's what I wanted to hear :-)
PostPosted: Sun Dec 06, 2015 7:48 pm
What are the specs for a GR 266 compared with a Wade 104.
PostPosted: Sun Dec 06, 2015 7:56 pm
Im not sure, they are advertised on mini kingdom site.
Just took a snap a the top of my pistons, how do I tell what size they are? None have std or any oversize marks that I can see anywhere. Below is a pic:
PostPosted: Sun Dec 06, 2015 8:46 pm
GR 266 + twin HS2s, a GR modded 202 head and an LCB, refaced rockers stock 998s with a new HD shaft for under a grand?
still on your unbuilt 998?
go for it.
PS. please compare apples with apples.
PostPosted: Sun Dec 06, 2015 9:03 pm
Anyone in the know able to fill me in if they are standard sized pistons?
Steve
PostPosted: Sun Dec 06, 2015 9:24 pm
Steve
Maybe - Many standard pistons don't have any size markings. Do you have any vernier callipers to measure the bore size? Well worth getting a set especially if your going to be doing your own repairs.
PostPosted: Sun Dec 06, 2015 9:28 pm
I have a friend who does the bore side of things so might have to take it down to him to measure :-). What is the standard 998 measurement ?
Steve
PostPosted: Sun Dec 06, 2015 9:29 pm
64.6mm near enough.
PostPosted: Sun Dec 06, 2015 9:45 pm
Thanks Doc!
PostPosted: Tue Dec 08, 2015 8:02 pm
timmy201 wrote:
The standard 998 head is ~24.5cc with C/R of 8.6:1
The standard 12G202 head is 26.1cc.
You'd need to skim the head or use some pistons with less dish in them.
I bought a "stage one kit" from minispares last year for about $500:
Exhaust manifold
Full exhaust
Intake manifold
KN filter
To go with a HS4 single carb.
Just a quick qu, is the 26.1cc for the 12g202 just the head volume or head volume and volume of dished piston combined?
PostPosted: Tue Dec 08, 2015 9:05 pm
Head volume only.
Users browsing this forum: Bing [Bot] and 72 guests
